High and low speed needle settings
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> High and low speed needle settings
Page: [1]
Login
High and low speed needle settings - 6/22/2008 9:50:38 PM
back179
Status: offline
Hi all
I hope someone can help me here. I have the Redcat Earthquake and was wondering what the high and low speed needle settings approximately are when the car is properly run-in? My car is run-in but my high speed needle setting is about 3 turns from out and my low speed setting is about 4 turns from out, does this sound correct? I can't get the car to run at any other setting besides these so i'm presuming that this is the correct settings for the motor, but then i read that normal settings for car engines is about 1 - 2 turns for the high speed needle and about 1 turn for the low speed needle. Are the engines on these cars different from other engines?
I have done the pinch test for the low end and it seems correct. Also the temperature of the car is fine. One thing to note is that i did find an air leak between the carb and the motor but i fixed that with high temperature gasket sealant.
So basically i'm interested to know what your settings are when you have completed the break in procedure?
Thanx for the help!
       Post #: 1
RE: High and low speed needle settings - 6/22/2008 11:18:31 PM
firebird78
Status: offline
try 2 1/2 turns from all in on the high and 3 1/2 turns from all in on the low...also make sure you idle is set at 1 mm open by looking down into the carb (you need your radio system turned on to do this)...this should get you running
_____________________________
HIMOTORACINGUSA, bodies by blue, allaboutfunhobbies
RXB-1, MTR-3, torpeda, torpeda pro, rapida
(in reply to back179)
       Post #: 2
RE: High and low speed needle settings - 6/23/2008 12:01:04 AM
Chubbysdad
Status: offline
3 and 3 is a good starting point on the earthquake.
Cen truggy, Bigfoot 1/5th, Cen buggy, Mg16, Redcat Earthquake
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.719RCU1
