osterizer
MD, USA Status: offline
Most of us have a beater heli and a good one. The beater has to be capable of the least of the maneuvers and capable of doing the harder stuff you're trying to learn. From what you've described, the Belt isn't a bad beater for you- it's easy to fix (compared to the Gazaur) and it's a lot easier to fly if it's set up well. The Gaz is a bit of a boutique heli and though it's a luv to fly, it isn't until you have the basic skills. I'd suggest spending most of your time on the Belt for new things- it's cheaper to fix . Better still, get a good sim like RealFlight or Phoenix, and learn your new maneuvers there where they don't cost anything when you crash, then work them out on the Belt, and then try them on the Gazaur. The best place to learn new things is on a simulator first, then on a cheap heli, and only after you've gotten it down, on a nice heli like the Gaz. Your blade and pinion choices sound good. The main thing is to keep under 15g blades if you're going up in head speed. Most 325s will be fine on 11T- that's why I said it the way I did .
