noobflyer01
Nice canopy there edwin. .. glad to see back here on the forums. i just ordered the dx6i from ushobbysupply. Helitubbies i do believe you have the same tx. could i get the settings on it for your mars? cant wait to get the new full range dx6i. I'm getting alot of weird things on my heli. i've changed everything and still get the same bad results. i thought it might be my transmitter so i ordered the dx6i to see if that's really causing my problems. two different helis that behave in the same way with new motor, esc, servos, bec, gyro could only mean its the transmitter. here's the problem.. everything starts out perfect than just when i'm about to lift off the tail starts wagging big time. no amount of gain or throttle can make it go away. changed servo, gyro, esc, and motor with same results. lets see if the dx6i will solve my problems.
_____________________________
EF mash rescue Co-ax, HBK2, HBFP, Belt CP, Blackhawk 450, EXI 450, trex 450 SA, mars 480, mini titan e325, gazaur poseidon.
