MJD
ON, CANADA Status: offline
quote:
ORIGINAL: longdan My take on it is, that I basically have (almost) a 100% guarantee of not ruining a 1/2A engine under normal sport flying use if I use 100% castor (and don't run it lean), but is this guarantee reduced if the castor content drops to 50% of the total oil content? I do not believe so for one minute. Offering my personal opinions on the subject: - A sensible fuel for 1/2A's with ball and socket joints has 50% of castor as minimum in it's oil package, and the balance synthetic. - I think it is smart to have at least 20% total oil. Is 22-23% "best"? Maybe. 20% might be best. Doesn't hurt. - I also think it is acceptable to run 18% 50/50 syn/cas if that is all you have available. I have done so a lot, in .049 reedies, and enjoyed long life and good performance. The caveat is to know how to set a 1/2A needle with some respect for the engine. - Too much oil degrades performance and doesn't add to longetivity, at least not enough to warrant the negative issues. - The 20% castor/80% synthetic rules apply to typical larger sport engines, ringed or not, with plated cylinders esp. although a broken in lapped engine might be happy too but whatever - I don't own many of those. Anyhow, 1/2A's work on different rules of thumb. - 1/2A's with bushed conrods are probably content on 20% castor/80% synth, but maybe 50/50 is better for the other benefits castor offers. - The conrod and specifically the bushing/bearing design and metallurgy have lots to do with overall oil requirements, both in type and percentage. So don't be surprised by the special needs of the ball-and-socket engines. Digressing from oil a bit while I'm at it: - This is not an oil issue, but 15% is the minimum nitro content for Cox .049's, and 25% for .020's and especially .010's. Below these levels, from my experience, they start to run like crap and will p- you off eventually. And I don't care about Texaco engines, or the the occasional guy who insists they run 10% in their .049's and "that's all they need", because I think it is BS. While you might be able to needle them to the point they stay running, why be a miser when the only return is marginal performance and handling? 25% is ho-hum everyday sport fuel for 1/2A's and smaller - the numbers are just different with these guys. - Don't put Armor-All in your fuel. The silicone oils poison the catalytic action of the glow plug element over time with deposits, and shorten plug life. A better idea is to a good job balancing props and the tank installation. Many fuels contain anti-foaming additives anyway. - Balance your props with all the care and skill you have at your disposal. - Keep everything to do with the engine and fuel cleaner than clean. As I said, these are my personal opinions! But I've run just a few of these guys in my lifetime. Way more than many, and way less than some. But they always seem to run well for me and I still love small engines, so something must be working. MJD
< Message edited by MJD -- 6/24/2008 4:38:07 AM >
