os 55ax help
Tower Hobbies
Logged in as Guest
  Printable Version
25%Yak54 with SPE26 COMBO - ARF
Seller:  peakmodel
Details:   $499.00   |  10/9/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> os 55ax help
Page: [1]
Login
os 55ax help - 6/23/2008 10:10:34 PM
guesty7
Status: offline
Hi, i,ve got a u can do 46 and i am using an os 55ax as the powerplant. Its had about 30 flights now and i love it but recently the engine has been playing up. After about 25 flights suddenly with no warning the engine starting running rough. left on about half throttle or just below for a few seconds its starts to cough and splutter as though it is rich. ive tried quite a few things like altering the idle needle, cleaning out the carb, changing the plug (although it was a used one).its Probably be something simple but i would apreciate some advice
       Post #: 1
RE: os 55ax help - 6/24/2008 12:09:40 AM
larry11
Status: offline
Make sure all the bolts are tight. IE: head bolts, carb bolts, the nut on the needle valve.
They have been known to loosen up.
(in reply to guesty7)
       Post #: 2
RE: os 55ax help - 6/24/2008 1:33:08 AM
Live Wire
Status: offline
How about trying different fuel, did you run out of the first you were using
_____________________________
Larry K AMA 36417
WACO Brotherhood #34
       Post #: 3
RE: os 55ax help - 6/24/2008 6:09:15 PM
guesty7
Status: offline
We were originaly using 5% then we went to 10% but we ran a tank through before we flew it on 10 and it seemed fine. Also it has had more than half of the flights on 10% and i had no problems it just came on sudenly. Me and my dad are now about to go try a few more things to se if we can sort it. Ill keep you up to date in case anyone else has simular problems
(in reply to Live Wire)
       Post #: 4
RE: os 55ax help - 7/8/2008 9:17:08 PM
sidav
Status: offline
look at the other thread on q&a did you manage to sort it?
       Post #: 5
RE: os 55ax help - 7/8/2008 9:32:41 PM
draftman1
Status: offline
did you check the tank? have you had a hard landing latley? the fuel clunk can get bent inside the tank from a hard landing. the fuel line could have a pin hole in it, and you wouldnt see it. or the tank and stopper, are they in good shape? the stopper can leak air also. when I gett bad running engines, the tank is usually the culpret. very rarely its the actual engine that is having the problem.
(in reply to sidav)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.219RCU1
