advanced2
SC, USA Status: offline
Hello Guys, I have used Hitec digital servos for years, especially in IMAC. And many,....many IMAC guys use Hitec servos. I am using the HITEC servos in my pattern/IMAC birds,5955,5625,5645,5245 mini digitals and they all work very well and are very precise. I have used and still use Futaba and JR servos and they are great servos,...no doubt! I think most guys that fly Futaba and JR are seeking to be brand specific with respect to the transmitter brands they fly with (Futaba, JR and Airtronics). You will not find any top pilots using Hitec servos usually due to sponsorship commitments or other political reasons. Plus, in the past Hitec would not provide sponsorship for servos only. The only well known pilot I know of that was sponsored using Hitec servos was also using a Multiplex transmitter and he is not from the USA. I believe if Hitec had a "top of the line" radio that would compare to the Major name brands today we might see more pilots flying with them. If money is an issue, the Hitec are great either way. However, if you can afford the major name brand equipment by all means keep it the same! In pattern the problem you will find, which was already stated, most guys don't use them. So, if you get yourself in a pinch at a contest and need a gear or a servo arm, etc...........have some spares because no one else will. Example:I switched from Airtronics equipment in 2003, great stuff, but the local hobby shop didn't carry it, Tower didn't carry much and I became frustrated one day and ordered a Futaba 9ZWC2 and never looked back (the dominate radio brand in our local club). Opinions will vary, this is only my opinion, so good luck! Bill Holsten Dist#2
