RE: NEW 3MM106cc twin coming
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NEW 3MM106cc twin coming
Page: <<   < prev  1 [2]
Login
RE: NEW 3MM106cc twin coming - 6/30/2008 5:23:17 AM
rctom
Status: offline
quote:
ORIGINAL: rajul
How did 3MM manage to get 3/4 lbs weight savings over the DA100? What alloy is used? The cooling fins look pretty thin and the mounting lugs are thick.
I am not exactly sure what they did to save weight. As most are aware the BME 115 weighs/weighed only 4 pounds due to almost obsessive attention to weight.
I do know this much. I started talking with them about the importance of weight over a year ago. They re-cast the cylinders to save weight, I know that much, and that's an expensive step to take. I suspect that they worked hard to reduce reciprocating weight because this allows the crankshaft to balance properly with less counterweight. Just a guess, but there are a lot of tricks to building a light engine that mostly require attention to detail.
I like to think that me staying on them about weight had an effect on the design. I had a feeling that it would be possible to hit somewhere between the DA-100 and the BME-115. The old BME 102 weighed about 5 lbs. and was an excellent engine.
TF
(in reply to rajul)
       Post #: 26
RE: NEW 3MM106cc twin coming - 6/30/2008 5:25:48 AM
rajul
Status: online
Thanks Tom. I'm keeping a close watch on this engine.
_____________________________
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
(in reply to rctom)
       Post #: 27
RE: NEW 3MM106cc twin coming - 6/30/2008 11:42:38 AM
Zi-Chun Lin
Status: offline
If second prototype have no problem we will release in mid of September!!!!
The second prototyppe will be out before mid of July!
(in reply to rctom)
       Post #: 28
RE: NEW 3MM106cc twin coming - 6/30/2008 2:07:52 PM
Scoubidou
Status: offline
Will the exhaust flanges be compatible with DA or 3W engines for those who want to run canisters or pipes?
Daniel
Seneca Engineering
http://www.seneca.ca/
(in reply to Zi-Chun Lin)
       Post #: 29
RE: NEW 3MM106cc twin coming - 6/30/2008 2:51:39 PM
rctom
Status: offline
quote:
ORIGINAL: Scoubidou
Daniel
Exhaust flange is same as 3mm TOC-53. The shape and size is the same as 3W, but the face is parallel to the cylinder bore, not angled like 3W. The engine will be supplied with mufflers and I'm already working on headers for it.
Hopefully by the time the engine is available as a production unit I'll have everything that's needed.
TF
(in reply to Scoubidou)
       Post #: 30
RE: NEW 3MM106cc twin coming - 7/23/2008 10:49:54 PM
show871
Status: offline
quote:
ORIGINAL: rctom
quote:
ORIGINAL: show871
Do you have any ballpark estimate on when I could buy one from you? 3 months? 6 months?
I estimate 3 months, but that may be optimistic. They are working diligently but carefully, and they/we do not want to release something with problems.
TF
How is this looking at this point, and do you have any new 100 class airframes coming out to slap it into?
(in reply to rctom)
       Post #: 31
RE: NEW 3MM106cc twin coming - 7/24/2008 12:15:53 AM
bdbd
Status: offline
Any plans for a 150 or 170 or something in that class?
       Post #: 32
RE: NEW 3MM106cc twin coming - 7/24/2008 5:22:18 AM
rctom
Status: offline
quote:
ORIGINAL: show871
Good question. My last communication with them was about 3 weeks ago. At that time they were working on a set of rev. 2 prototypes, the first one ran well but the foundry made some mistakes making the castings, at least that was my understanding. The new engines may be running by now, but my contact who speaks english has been out for 3 weeks and will probably be gone for another week or two, so I won't have any real solid info for a while. There are lots of people working on it but I can't communicate with most of them.
Yes, we have two new 100cc planes coming in September. A 105" Extra 260 replaces the Extra 300, basically the same plane with some small engineering changes and a new look.
And then we are at last releasing the 102.5" Edge 540 which is a really nice lightweight 3D beast.
Thanks for asking. It would be really nice if the new engines became available with the new planes, wouldn't it?
TF
(in reply to show871)
       Post #: 33
RE: NEW 3MM106cc twin coming - 8/31/2008 11:26:38 PM
show871
Status: offline
Any news on this motor? 871
(in reply to rctom)
       Post #: 34
RE: NEW 3MM106cc twin coming - 9/1/2008 2:04:13 AM
rctom
Status: offline
Only this. I spoke with them a few days ago, they expected to receive revised engines in the next week or so, Then will begin testing, which will take an unknown time.
You guys need to understnd that a delivery date can not be predicted until the engine has passed testing. Until them there's no way to be sure it will pass the test, a failure could set the whole project back.
I'll let you know when I know something.
TF
       Post #: 35
RE: NEW 3MM106cc twin coming - 9/8/2008 12:51:44 AM
Kcripto
Status: offline
Please keep us informed , I have a dl-100 in a GP Extra 330L, but I interested in the 3mm 114 for my new QQ python...
(in reply to rctom)
       Post #: 36
RE: NEW 3MM106cc twin coming - 9/17/2008 2:26:00 AM
show871
Status: offline
bump
(in reply to Kcripto)
       Post #: 37
RE: NEW 3MM106cc twin coming - 9/17/2008 3:43:08 AM
rctom
Status: offline
Sort of good news. As of a couple daus ago they have all the parts in, now it's a matter of testing and QA. Let's just hope that all goes well.
TF
       Post #: 38
RE: NEW 3MM106cc twin coming - 9/21/2008 1:54:19 AM
rfn7635
Status: offline
Just recently I spoke with Bob about the dispalcement of this 3M engine. It's 106CC not 114CC (confirmed).
(in reply to rctom)
       Post #: 39
RE: NEW 3MM106cc twin coming - 9/21/2008 3:53:43 AM
rctom
Status: offline
Hence the title of this thread, "NEW 3MM106cc twin coming".
Who's Bob?
TF
(in reply to rctom)
       Post #: 40
