Campgems
CA, USA Status: offline
With 13 ch of equipment on your setup, do you have a regulator? I still think you have one component drawing the receiver voltage to low. Plug a Voltwatch into the receiver, use a Y if you have to, and see what the voltage is. Can you get either of your receivers to work on your friends 14z on the bench? Can you get his receiver to link up to your TX. Don Edit Add. You mentioned that "everything" is new. After working in the computer industry for over 30 years, and trouble shooting systems with hundreds of units on it, the first thing we always looked for in a head scratcher failure was, what was added recently. The first 10 hours of an electronic component's life represents it highest failure rate. It is quite possible that a servo, retract, brake, etc just died and took down the system. This is why you are going to have to start isolating . A receiver, battery, and one servo on the bench is where to start. You already have a clean bill of health from Futaba on the TX. Don
< Message edited by Campgems -- 6/24/2008 8:18:07 PM >
