2 s lipo charging.
Tower Hobbies
Logged in as Guest
  Printable Version
AXIAL AX10 SCORPION CRAWLER 12MM HEX WHEEL EXTENSIONS - RTR
Seller:  wheelextensions
Details:   $20.00   |  8/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> 2 s lipo charging.
Page: [1] 2   next >   >>
Login
2 s lipo charging. - 6/24/2008 8:48:07 PM
nitrosportsandrunner
Status: offline
i just got a used 2s lipo, and dont know what is safe rate to charge it at. my charger cant do over 2.5 amps. my 3s lipo can be charged at 5amps, but i wasnt sure how much lower i should go for a 2s. oh, its a 2s, 15c, 24burst, 4000mah lipo.
_____________________________
VXL on 3s lipo, wheely king crawler, tt01 drifter
       Post #: 1
RE: 2 s lipo charging. - 6/24/2008 8:53:00 PM
t9dragon
Status: offline
What charge are you using?
(in reply to nitrosportsandrunner)
       Post #: 2
RE: 2 s lipo charging. - 6/24/2008 8:58:11 PM
Status: offline
dynamite vision peak ultra.
(in reply to t9dragon)
       Post #: 3
RE: 2 s lipo charging. - 6/24/2008 9:26:01 PM
AutoXMan
Status: offline
It doesn't matter whether its 3S or 2S. It depends on the mah of the battery. its 1c = 1amp charge racte generallry. 4000 mah battery = 4 amp charge rate.
V-tec rep
       Post #: 4
RE: 2 s lipo charging. - 6/24/2008 10:07:37 PM
carlbellybutton10
Status: offline
quote:
ORIGINAL: AutoXMan
but his lipo is 15c, so wouldn't that make it 15 amps by what you are saying?
(in reply to AutoXMan)
       Post #: 5
RE: 2 s lipo charging. - 6/24/2008 10:21:20 PM
1maxdude
Status: offline
No, 15c means the output of the battery. 1c = however many amp hours. In this case 4000 milliamp hours = 4 amp hours. So you charge it at 4 amps maximum. A 15c 4000mah can output a constant 15 x 4 amps which is 60 amps. Regardless of cell count, always charge your battery at 1c, take the mah of the battery, divide by 1000, thats your charge rate.
(in reply to carlbellybutton10)
       Post #: 6
RE: 2 s lipo charging. - 6/24/2008 10:22:06 PM
Druss
Status: offline
No, the charge rate and the discharge rate are different....
Charge rate is always 1C regardless of what the discharge rate is. So 4amps is right for a 4000mah battery.
       Post #: 7
RE: 2 s lipo charging. - 6/24/2008 10:29:08 PM
Speed-Limit
Status: offline
so if you had a 3000mah battery you would charge it at 3 amps. and 4000mah at 4 amps. and a 5000mah at 5 amps and so on and so forth?????
Hyper ST
Life moves pretty fast. If you dont stop and look around once and a while, you could miss it.
(in reply to Druss)
       Post #: 8
RE: 2 s lipo charging. - 6/24/2008 10:33:59 PM
sxcurtin
Status: offline
speed limit, exactly, or you could use lower charge rate but it just takes longer.
Bandit xl-5 with vxl system and protekrc 3s 20c 4000mah!!!!! Some upgrade from titan and tenergys!!!!!
(in reply to Speed-Limit)
       Post #: 9
RE: 2 s lipo charging. - 6/24/2008 10:44:00 PM
Speed-Limit
Status: offline
so "nitrosports" would probably want to get a different charger, since he has a 4000 mah batt and a 2.5 amp charge rate? or atleast the charge would take longer, like twice the time
Hyper ST
(in reply to sxcurtin)
       Post #: 10
RE: 2 s lipo charging. - 6/24/2008 10:55:02 PM
sxcurtin
Status: offline
4.0 /2.5=1.6(1hr36mins) not bad IMHO.
       Post #: 11
RE: 2 s lipo charging. - 6/24/2008 10:59:40 PM
Speed-Limit
Status: offline
that isnt bad. but i have never had an electric, but i am looking for one. my brother has a nicd in a rustler and that thing takes like 4 hours to charge so i thought it might be the same for lipo, guess not!!
Hyper ST
       Post #: 12
RE: 2 s lipo charging. - 6/24/2008 11:02:14 PM
sxcurtin
Status: offline
ya thats probly giving 300-500mah!!!!
god bless lipo!!!!
       Post #: 13
RE: 2 s lipo charging. - 6/24/2008 11:22:15 PM
Status: offline
yeh, my 5000mah 3s lipo takes 2hours to charge at the max 2.5 that the charger can do. i guess its safe to charge the 2s at 2.5 as well. its nice if it takes alittle less time than the 3s.
2.5amps charging max for lipo is the only real drawback to my charger. but it costs alittle less than other lipo chargers, and is really easy to use.
       Post #: 14
RE: 2 s lipo charging. - 6/24/2008 11:46:40 PM
sxcurtin
Status: offline
how much did the charger cost?????
