APC 15X4W Question
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> APC 15X4W Question
Page: [1]
Login
APC 15X4W Question - 6/25/2008 5:40:22 AM
Sign Guy
Status: offline
I just purchased an APC 15X4W prop for my Saito 100. The problem I have is the thickness of the prop and the spinner/jam nut that I have. The spinner adapter/jam nut isn't deep enough to jam up against the prop nut by about 1/2 an inch. What do I use for a spacer or where can I get a deeper spinner adapter?
_____________________________
"It was supposed to do that.....Right?"
       Post #: 1
RE: APC 15X4W Question - 6/25/2008 8:25:08 AM
The Ghost
Status: offline
I take it that the lock nut wont tighten against the prop nut? Two ways out of it, 1) make a spacer between the engine prop driver and the back of the spinner, 2) use a different type of lock nut and a new spinner adapter nut.
Cheers
Remember, Always look after the ORGANIC part of the model
(in reply to Sign Guy)
       Post #: 2
RE: APC 15X4W Question - 6/25/2008 6:27:19 PM
broke_n_bummin
Status: offline
I've cut out the middle of a broken spinner to use as a spacer before.
< Message edited by broke_n_bummin -- 6/25/2008 6:29:54 PM >
I may have to give up R/C Airplanes and Golf ... They make my Torrets act up...
(in reply to The Ghost)
       Post #: 3
RE: APC 15X4W Question - 6/26/2008 6:37:28 PM
Flyboy1958
Status: offline
I would check out tru-turn web site and figure it out.
(in reply to broke_n_bummin)
       Post #: 4
RE: APC 15X4W Question - 6/27/2008 12:28:24 AM
MetallicaJunkie
Status: online
is gonna rip on your 100.... its perfect for my 91 turning 9300 with 10% and rips the air...sounds great
Freestyle Junkie
Revver Bro #217
(in reply to Flyboy1958)
       Post #: 5
RE: APC 15X4W Question - 6/27/2008 1:18:17 AM
Deadeye
Status: online
My 82 swings a 15X4 APC. Seems like that is a little small for a 100.
The USA is not a free country anymore
(in reply to MetallicaJunkie)
       Post #: 6
RE: APC 15X4W Question - 6/27/2008 5:03:19 AM
Sign Guy
Status: offline
I've been told by many a 15X4W or 16X4W is the prop of choice for this motor. The instructions call for up a 15 X 6
(in reply to Deadeye)
       Post #: 7
RE: APC 15X4W Question - 6/27/2008 5:07:40 AM
Jester241
Status: offline
I'm just using a spare engine washer inbetween my prop and the washer/adapter nut. It works fine and hasnt came loose yet without a jam nut.
       Post #: 8
RE: APC 15X4W Question - 6/27/2008 5:09:08 AM
Deadeye
Status: online
I've only swung a 14X8 on my 100. 15X6 or 16X4 fall into the drop in pitch for increase in length rule of thumb. Just make sure it doesn't over rev.
       Post #: 9
RE: APC 15X4W Question - 6/27/2008 5:20:25 AM
Sign Guy
Status: offline
I flew it with the 14 X 8 and it has like ZERO vertical. The load on a 16 X 4 is the same as the 14 X 8 a load factor of 36. The 15 X 4 is a little less, but being wide bladed, still shouldn't over-rev the motor.
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.535RCU1
