os 61sf    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Turbine Epic Victory Jet - Kit
Seller:  cat-boi
Details:   $3,600.00   |  5/24/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Tachometer Readings >> os 61sf
Page: [1] 2 3   next >   >>
Login
os 61sf - 6/25/2008 8:15 PM
MetallicaJunkie
Score: 243
Last Login: 5/24/2013
Status: offline
11800 peak on a MAS 12x7 scimitar stock muffler
10% nitro
_____________________________
"Propellers are notorious for inflicting serious bodily harm while vigorously defending their space" George Aldrich
Hide Signatures
       Post #: 1
RE: os 61sf - 6/26/2008 9:36 PM
MetallicaJunkie
Score: 243
Status: offline
12200 peak on a MAS 12x7 scimitar macs head on a macs muffled pipe (untuned)
10% nitro
Hide Signatures
(in reply to MetallicaJunkie)
       Post #: 2
RE: os 61sf - 7/11/2008 11:04 PM
rainedave
Score: 100
Last Login: 4/24/2013
Status: offline
Stock muffler; 10% Powermaster; APC props; warm, humid weather; rich of peak:
12x8 - 10,780
12x6 - 12, 140
11x10 - 10,860
11x11 - 9,780
David
Hide Signatures
       Post #: 3
RE: os 61sf - 7/24/2008 7:33 PM
rainedave
Score: 100
Status: offline
I'm hoping to run mine with the pipe and a 12x8 today or tomorrow.
I'll take some tach readings.
David
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to rainedave)
       Post #: 4
RE: os 61sf - 8/8/2008 10:40 AM
MetallicaJunkie
Score: 243
Status: offline
looks good.... i plan on running mine as well, i finally got around to putting the finishing touches on the bird the SF is going into..... i cut about one inch off the stock length header, hopefully ill get it to sing higher ill be using a 12x6 xoar/jfx black prop..
any new numbers, with yur set up?
Hide Signatures
       Post #: 5
RE: os 61sf - 8/8/2008 6:53 PM
MetallicaJunkie
Score: 243
Status: offline
13,300 peak w/ 10% @ sea level with a 12x6 xoar nylon and 1" cut off the header. Does hat sound about right, this is my first tuned pipe setup i have tached
Hide Signatures
       Post #: 6
RE: os 61sf - 8/9/2008 7:06 AM
rainedave
Score: 100
Status: offline
MJ, I ran my SF w/pipe for a short while, but I didn't take any tach readings. I can't really do a lot of running on the patio, so I need to take the engine to my field. I cut my header to 6" which is what Macs recommends for this engine. But, I extended it a bit with a longer Aerotrend blue coupler. I'm using the 10cc Long Stroke quiet pipe #1062. Anyway, it really sounded strong with an APC 12x8 and as I tune the length I'm sure it will get better.
I think you 13,300 sounds good. It will probably go up as you shorten the header. However, I think this engine was intended to be propped around 12,000 or so. I'm setting mine up for a 12x8 or 11x10 (they turn about the same) and I hope to get close to 12,000. I'll be very happy with that, if I get it.
BTW, Graves R/C is selling the #1062 long stroke pipe for $52.99. It's the cheapest I've seen anywhere. I got it in two days; great service, IMO:
http://www.gravesrc.com/MAC_S_MUFFLERS_QUIET_PIPE_LNG_STRKE_10CC_p/mac1062.htm
Macs lists this pipe for $100.95!
I'll post again when I have some numbers. Maybe by next week. Oh, it's going in my Bridi UFO:
http://www.rcuniverse.com/forum/m_4017336/tm.htm
David
Hide Signatures
       Post #: 7
RE: os 61sf - 8/9/2008 11:45 AM
MetallicaJunkie
Score: 243
Status: offline
Hmmm, i think i'll take your advice and run a higher pitch prop, as you know way more about these kinds of things... its just that when ever i hear a tuned ppe i used to hearing them scream.. I know my pipe is a macs, it has a baffle in it... but im not sure its the quiet pipe.... you got a good deal Gravesrc is awesome,,,, i can remember when i was a teen you could get the combo(pipe/header) for about the same price as a pipe is going for now. So you lengthened the header with a longer couple to get less RPM? My SF is in a Miss Norway.... i am going to maiden her today According to the original owner it hasnt flown in over 20 years
quote:
ORIGINAL: rainedave
David
Hide Signatures
       Post #: 8
RE: os 61sf - 8/10/2008 1:14 AM
rainedave
Score: 100
Status: offline
Please post your Miss Norway info in the Classic Pattern forum; a lot of folks will be interested to see how it flew.
The only reason I extended the pipe was to make sure I had some leeway to make adjustments. The Macs info might be for maximum rpm and I want to work up to that gradually.
David
Hide Signatures
       Post #: 9
RE: os 61sf - 8/13/2008 12:14 AM
MetallicaJunkie
Score: 243
Status: offline
Ok will do, my maiden flight with her went well. I didnt do any abrupt maneuvers with her but she knife edged nicely, did nice hammerheads,loops, and axial rolls.... i ended up like the sound of the motor best with a 12x6 apc, i tried an 11x9 but the motor didnt seem to like it i didnt have a 12x8 to try out
Hide Signatures
       Post #: 10
RE: os 61sf - 9/19/2008 7:12 AM
rainedave
Score: 100
Status: offline
I finally tached my SF .61 with a Mac's long stroke quiet pipe.
APC 11x10, Powermaster 5% nitro: 11,630
I cut the header to 6" as the Mac's site suggests. I haven't done any serious tuning yet.
David
Hide Signatures
       Post #: 11
RE: os 61sf - 9/21/2008 12:20 PM
DarZeelon
Score: 163
Last Login: 9/6/2011
Status: offline
quote:
ORIGINAL: rainedave
David
This number, Dave, is a respectable 1.42 HP.
...But it's not exactly piped engine material, I am afraid.
MJ's number on the 12x6 Xoar sounds exaggerated, however, at 2.26 HP
Experience with this engine on a length-adjusted pipe, suggest ~1.85 HP to be a typical real-life output.
Without a tuned-pipe (i.e. with the normal, included OS muffler), about 1.25-1.3 HP is the expected output.
Dar Zeelon - ISRAEL - ddzeelon@gmail.com
MVVS - Jett - MS Composit - Rossi - Mejzlik
Hide Signatures
       Post #: 12
RE: os 61sf - 9/21/2008 8:06 PM
rainedave
Score: 100
Status: offline
Thanks Dar. I have not yet begun tuning the header length. That figure is with the 6" starting point and an addition 1/2" gap from the coupler. If I reach 12,000rpm I will be more than satisfied. Running 15% nitro instead of 5% will be good for a couple of hundred, too.
David
< Message edited by rainedave -- 9/21/2008 8:07 PM >
Hide Signatures
(in reply to DarZeelon)
       Post #: 13
RE: os 61sf - 9/21/2008 10:37 PM
DarZeelon
Score: 163
Status: offline
Dave,
It is the length adjustment...
The RPM difference between 5% and 15% would typically be ~200-300...
Hide Signatures
       Post #: 14
RE: os 61sf - 9/22/2008 3:28 AM
rainedave
Score: 100
Status: offline
Then, I'll easily hit or break 12,000 when I get the header trimmed down and use hotter fuel. 12, 250 would equate to 1.65hp; 9.26lbs of thrust and a pitch speed of 100mph. Perfect for my 7 1/2lb Bridi UFO.
David
Hide Signatures
       Post #: 15
RE: os 61sf - 11/9/2008 7:51 AM
anuthabubba
Score: 108
Last Login: 2/1/2013
Status: offline
OS 61SF, well used, stock muffler, Omega 10%...
12~8 wood Zinger = 10,000
11~10 wood Zinger = 10,000
13~6 APC = 11,000
13~8 APC = 10,000
More later.
Terry in LP
edited for: Later results. Same engine/fuel but all APC props.
12~7 = 11,500
11~10 = 10,600
13~9 = 9100 (this is a heavy prop)
14~5N = 11,200
Gotta get my flightbox battery installed so I can use a starter instead of a chicken stick.
< Message edited by anuthabubba -- 11/10/2008 2:04 AM >
Hide Signatures
       Post #: 16
RE: os 61sf - 11/12/2008 8:32 PM
MetallicaJunkie
Score: 243
Status: offline
[/quote]
[/color]
[/quote]
Sorry im replying so late but thats the number my globee tach gave me, perhaps its maybe off cuz i was taching it in the shade, but i doubt it
Hide Signatures
       Post #: 17
RE: os 61sf - 11/13/2008 6:54 AM
rainedave
Score: 100
Status: offline
13,300 is really too high for this engine. If it were an FSR I'd say great, but the SF was designed to spin in the mid elevens. A 12x8 or 11x10 are about the best props to use.
David
Hide Signatures
       Post #: 18
RE: os 61sf - 11/14/2008 10:37 AM
MetallicaJunkie
Score: 243
Status: offline
ill have to give a higher pitch a try, im just so used to trying to get higher rpms out of my engines, and hearing them scream, especially since its on a pipe
Hide Signatures
       Post #: 19
RE: os 61sf - 11/14/2008 4:51 PM
rainedave
Score: 100
Status: offline
I fully understand. Think of the SF/RF series as OS's attempt to design a 2-stroke that would run more like a powerful (for its day) 4-stroke: quieter running on bigger props at lower rpms. Remember, it wasn't too long after the Hanno was in production that pattern fliers switched to 120 4-strokes. In retrospect, the SF/RF engines represent a transitional time period between the short stroke screamers turning 11x7's to the 120 4-strokes turning high pitched props.
David
Hide Signatures
       Post #: 20
RE: os 61sf - 4/17/2009 12:16 AM
rainedave
Score: 100
Status: offline
I ran my SF with its Mac's 10cc long stroke quite pipe again today. This time I surpassed my target rpm of 12,000.
Temp: 67°
Powermaster GMA 5/22
OS #8 plug
APC 11x10
12,128
1.6hp
8.72lbs. static thrust
Calculated prop speed is 99.8mph. This setup is extremely quite. Below 1/2 throttle it's not much louder than a 4-stroke.
David
< Message edited by rainedave -- 4/17/2009 12:18 AM >
Hide Signatures
       Post #: 21
RE: os 61sf - 4/18/2009 12:27 AM
rainedave
Score: 100
Status: offline
I cut another 1/4" off and I think I'll stop there. Length of my header is now 5 3/4" and Mac's web site suggests 6" for this engine.
Temp: 70°
OS #8 plug
APC 11x10
12,337
1.68hp
9.02lbs. static thrust
This is probably about the maximum power this engine will produce with this prop. Going up to 15% nitro would add a bit, too. Though, nine pounds of thrust is a lot for an 11" prop, and the calculated speed is 101.5mph.
I have an extra backplate with a pressure tap and a pump. If I ever come across an #86 pump carb I'll see if that adds anything, but those carbs are extremely rare unless you buy the whole engine.
David
< Message edited by rainedave -- 4/18/2009 12:32 AM >
Hide Signatures
       Post #: 22
RE: os 61sf - 4/18/2009 2:06 AM
Trinut
Score: 105
Last Login: 5/25/2013
Status: offline
Ok, I'll admit it, I think I paid a record price for a carb recently.
Over $100.00 for a hanno special carb, 6P.
I"m building a hanno special from parts, all new parts, in fact.
It will be using a perry pump, and I'm port matching a standard RF block.
And a Shadel piston/Liner. I'll try and get it together soon and post something.
It's not really a hanno, just a fancy SF/RF ......
Hide Signatures
       Post #: 23
RE: os 61sf - 4/18/2009 2:08 AM
rainedave
Score: 100
Status: offline
Sounds like a great project. Let us know how it progresses.
David
Hide Signatures
(in reply to Trinut)
       Post #: 24
RE: os 61sf - 4/18/2009 2:19 AM
Trinut
Score: 105
Status: offline
I would think these old piped .60 size engines would have a hard time beating a super tiger .90 from a cost, weight and performance standpoint (at $119.00 it's lookiing pretty good in that respect).
From a sound and nostalgia standpomt.....priceless
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Tachometer Readings >> os 61sf
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
