4 tec problems
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> 4 tec problems
Page: [1]
Login
4 tec problems - 6/25/2008 10:06:06 PM
slurp91193
Status: offline
ok so i easy start my 4 tec .15 and no gas semms to be moving through the line. what is the problem do u think? how do u get the fuel tank off? the motor does not have too much compression but the guy i got it off said that it ran fine. any help is helpfull thanks.
_____________________________
- TRAXXAS ALL THE WAY -
- 3 TRAXXAS REVO 3.3''S
       Post #: 1
RE: 4 tec problems - 6/25/2008 10:30:59 PM
Osirisf16
Status: offline
Sorry, but i didn't understand. Your engine is running and you can't see any fuel in the fuel tube? So, how the engine working? Be sure not to look the fuel tube that connects the tank with the exhuast, but the fuel tube that connects the tank with the carb.
Kyosho Evolva M3 - OS VZR / Kyosho MP777 SP1 - OS Vspec / Hyper 8 - OS Vspec / Baja 5b
I CAN FLY, WHAT EVER THAT MEANS.
(in reply to slurp91193)
       Post #: 2
RE: 4 tec problems - 6/25/2008 10:48:41 PM
slurp91193
Status: offline
o sorry the engine wont start but i am looking at the one connected to the carb.and no fuel is going through it for some reason.
(in reply to Osirisf16)
       Post #: 3
RE: 4 tec problems - 6/26/2008 12:08:25 AM
slurp91193
Status: offline
any suggestions please i want to get my car going.
       Post #: 4
RE: 4 tec problems - 6/26/2008 12:30:21 AM
GYNAIKAS
Status: offline
Did you prime properly?
I simply love perfection...do something as good as you can or don't do it at all...
       Post #: 5
RE: 4 tec problems - 6/26/2008 12:38:44 AM
chris246810
Status: offline
you have to prime it by covering the exhust hole and press the starter untill you see the gas go into the engine
(in reply to GYNAIKAS)
       Post #: 6
RE: 4 tec problems - 6/26/2008 1:10:15 AM
slurp91193
Status: offline
i can hold it there all day and no fuel moves through it at all
(in reply to chris246810)
       Post #: 7
RE: 4 tec problems - 6/26/2008 1:33:09 AM
chris246810
Status: offline
are you using the ez start system? if so when its pluged into the connector and you press on the button do you hear the engine try and start up? does the engine try and start?
       Post #: 8
RE: 4 tec problems - 6/26/2008 1:48:26 AM
turbodremz23
Status: offline
have you tried blowing through the fuel line?
do you have an inline fuel filter that could be clogged?
carb could be full of old gummed up fuel...
       Post #: 9
RE: 4 tec problems - 6/26/2008 2:11:57 AM
CBM Racing
Status: offline
As mentioned, try blowing through pressure line from exhaust to see if fuel goes in, if not you have a plug in the system somewhere. 1st place to check is the high speed needle, see if some joker closed the needle on you, it happens . If it is not closed, pull line off the carb, and blow through pressure line again. If fuel shoots out (watch your eyes!) then you need to clean carb out good. Quick way is to remove hsn assembly and see whats plugging it and clean it out good. If no fuel from line, pull the lines from tank(both lines)and see if they are clear, if they are clear of obstructions, then only thing left is tank itself. You can try to clear it by hooking up fuel lines and using compressed air or motor cleaner spray to blast it out from carb end of lines. If you do this, prop the lid open as air compressor may blow the seams apart on tank if lid is sealed. If you blow into pressure line and can hear escaping air, but no fuel flow, may have to check lid seal for leaks, or look for cracks in tank. Took longer to type all this than to do it ! Good luck!
MMmm..Piepants..
(in reply to turbodremz23)
       Post #: 10
RE: 4 tec problems - 6/26/2008 3:24:08 AM
slurp91193
Status: offline
thanks a lot blowing in the line worked. next what are the factory needle setings for the .15 engine?
(in reply to CBM Racing)
       Post #: 11
RE: 4 tec problems - 6/26/2008 3:55:27 AM
turbodremz23
Status: offline
2 1/2 turns out on hi speed needle
1 3/4 turns out on low speed
good luck...if you need another one for parts let me know, I have one that is in good condition still
< Message edited by turbodremz23 -- 6/26/2008 3:57:27 AM >
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
