Joined: 1/26/2007 From: Tank Gunn, NT, AUSTRALIA Status: offline
quote:
ORIGINAL: Panzerfaust77
quote:
ORIGINAL: mariomart
As long as the crystals matched it would not matter what it was installed in and should work fine.
Cheers Mario
I thought the S&S transmitter was different?
The S&S transmitter is generic and only requires matching crystal sets to communicate. The NON S&S transmitter IS completely different (internally) and uses different protocols to communicate.
quote:
ORIGINAL: Dishmop
Are the receiver crystals the same plug in type as on other R/C receivers?
The Heng Long crystals are pretty unique to the Heng Long RC range (I've heard that some people have had limited success with non HL crystals, but overall the majority don't work).
Joined: 11/15/2007 From: Norwich, UNITED KINGDOM Status: offline
I suppose rather than looking for the crystal on the receiver it would be easier to change the one on the transmitter. (shows how much attention I have paid to the front panel on the transmitter until 10 minutes ago)
quote:
ORIGINAL: Dishmop
The crystal on the receiver is socket mounted on the smaller PCB. It will have the ID number (01 to 04) and frequency printed on it. The transmitter crystal MUST match the receiver crystal for it to work.
Joined: 4/20/2006 From: Launceston, AUSTRALIA Status: offline
Below is a pic of the HL Receiver board, the smaller of the two boards needed for "S&S". It is powered by the data cable, provides input signals to the main function board, and the antenna also attaches to this board.
I have fitted an RX14 S&S set into my 1/350 scale Bismarck, proportional speed in the water is nice for small areas
Motors, or rudder control?
Easiest way is keep the left-right motors for the propellers, and use the turret power feed (left stick right/left) for rudder control. Then you still have 4v feed from the elevation and 7v for the airsoft feature, as well as port for power extra items like smoke and barrel LEDs (if its armed)
