tadawson
TX, USA Status: offline
quote:
ORIGINAL: legine whats a gov? and what it throttle hold and does the belt CP have it? Thanks, Daniel A gov (or governor) is a means by which to regulate rotor head speed. On nitros, it is typically a separate device that uses a sensor magnet on the drivetrain somewhere to determine speed, and which controls the throttle servo to maintain a constant speed - not allowing it to get too low or too high (not to be confused with a limiter, which only controls overspeed . . . ). On electrics, this functionality is often built into the speed controller, although there are external units as well, and while the means of sensing speed differ, the net result is the same. Throttle hold is a switch funtion on your transmitter which will drop the throttle channel to idle while still allowing all other controls to function normally. It is used to perform autorotations in most cases, and can also be a "safety" in that it will not allow the heli to spool up when engaged. It is also the switch you hit last when you know you are going to crash, since it shuts down the power system, hopefully prior to impact, hopefully minimizing damage. Since it's a TX function, what model you fly is irrelevant as to whether you have it or not. Considering that most of the small electrics auto very poorly, on that heli, whether you have it or not is probably not that important . . . - Tim
