Pro 4 drifting setup
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Drifting >> Pro 4 drifting setup
Page: [1]
Login
Pro 4 drifting setup - 6/26/2008 4:09:15 PM
speed6
Status: offline
Hey boyz and girlz, i have a Pro 4 sitting on my shelf collecting dust, i always wanted to convert it to a drfit car but never found setups.
I read that the Pro4 actually is a great car for drifting, i also have all the hpi hop ups for it so all i need is a good setup.
Thanks for looking
       Post #: 1
RE: Pro 4 drifting setup - 6/26/2008 5:34:41 PM
Doonagoowin
Status: offline
What do you mean by setup? Basically all you need is some drift tires and go from there, trying out new things and seeing what works.
(in reply to speed6)
       Post #: 2
RE: Pro 4 drifting setup - 6/26/2008 7:59:37 PM
speed6
Status: offline
i mean do you run sway bars? how much toe in out etc... springs soft, hard, kick up etc...
What are the best drift tyres for the Pro 4 ?
(in reply to Doonagoowin)
       Post #: 3
RE: Pro 4 drifting setup - 6/27/2008 9:45:53 PM
DANDthekid
Status: offline
All of it is personal preference;
    -ABS Tires
    -Differential Tighten or Lock
    -Spring Tension Front/Rear Ratio
    -Performance Oriented Motor
    -Pinion/Spur Gear Ratio
    -Aluminum & Graphite Parts
Hope it helps
_____________________________
The closest thing to drifting is drifting RC. The next closest thing, is drifting around Homedepot with a shopping cart.
       Post #: 4
RE: Pro 4 drifting setup - 7/3/2008 10:56:11 AM
speed6
Status: offline
1. What are ABS tyres ??
2. I have a spool and one way would the best setup be a front one way and a rear spool ?
3. Spring Tension means softer easier to drift + what do you normally run front softer for more steering control?
4. What motor do you suggest ?
5. What about rear and front toe what is the average you run ? stock runs with 3 degree toe in rear and 2.5 degree toe in front.
6. What about kickup ?
(in reply to DANDthekid)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
