What causes this?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Beginners >> What causes this?
Page: [1]
Login
What causes this? - 6/26/2008 4:09:20 PM
goirish
Status: offline
I have a OS-46 that runs great. The problem is: when I pull the throttle back to idle-the motor slows down, then then after about 5 sec. It slows down more. If I set the idle where I want it when it slows down then it quits. Any suggestions. Like I say the motor runs great, good transition, WOT is good
_____________________________
(\__/)
       Post #: 1
RE: What causes this? - 6/26/2008 4:24:59 PM
MinnFlyer
Status: offline
That is usually a sign of being too rich on the low end.
At WOT the mixture is good but the needle valve is set slightly lean to compensate for the extra amount of fuel coming in from the low end adjustment, so when you throttle up, the transition is good.
Now you go back to idle, and the mixture slowly richens.
Try adjusting the low end by 1/8-turn increments. You'll have to richen the high end slightly each time too
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
(in reply to goirish)
       Post #: 2
RE: What causes this? - 6/26/2008 4:57:52 PM
goirish
Status: offline
I will do that Sir. Thanks for the information. So I am going to lean the lsn and richen the hsn is that correct?
(\__/)
(in reply to MinnFlyer)
       Post #: 3
RE: What causes this? - 6/26/2008 5:07:39 PM
MinnFlyer
Status: offline
Correct
Mike B.
       Post #: 4
RE: What causes this? - 6/26/2008 8:32:48 PM
ChuckW
Status: offline
Once you get the low speed set like Minnflyer pointed out, that .46-AX will idle long, long periods of time with no sign of quitting.
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.313RCU1
