gfyss
FL, USA Status: offline
You're within a couple of minutes of the Linebaugh field and Charlie's Hobby shop (lucky you!). Here's a link to the field's information (location, restrictions, hours, etc) http://www.baycityflyers.org/id16.html Since it's closed on Sundays, most of the heli guys come up to the main field up off of SR52 and US41 (end of Dale Mabry and go a bit further). Probably a 40-45 minute drive for you, the Veterans/Sun Coast Pkwy will cut off about 10-20 minutes of that Northbound, depending where you get off. The lights on Dale are timed for Southbound traffic so you would only save about 5-10 minutes on the return trip. The old time vs. money decision. Check out www.sunpass.com to see the toll rates for various exits. SR52 would be ideal, but SR54 and Dale Mabry exits aren't bad either. IMHO, I'd take the Dale exit since you're past the major traffic lights by then. The guy that runs Charlie's is a member of the club that runs Linebaugh (Bay City Flyers) and he'd be more than happy to set you up as a guest with him or someone else to check it out. I'm also in the club, but I've never been to Linebaugh so I'm not much use in that respect. Let me know if you decide to check out the main field. I'm usually there Saturday or Sunday mornings before the heat sets in. We keep the gate closed, but as long as the padlock isn't engaged, you can unlatch and come on in.
_____________________________
Comment heard from peanut gallery after heli crash: "Gee, I thought it would bounce more..."
