High idle problem
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> High idle problem
Page: [1]
Login
High idle problem - 6/27/2008 12:15:13 AM
Jamie22
Status: offline
Have a rossi 528x that wont idle down. I turn idle secrew down but still high. Temp were 240 and ran great just wont idle right. Im thinkin it mite be an air leak. Any other thoughts ?
_____________________________
Losi 8ight B, Jr8711/Jr8800s, Modded werks B3 with jp-2
WWW.BADRC.COM
       Post #: 1
RE: High idle problem - 6/27/2008 12:22:17 AM
rebelracer246
Status: offline
that or your linkages and epa isnt set right
http://www.youtube.com/watch?v=B6nJCigwtps
(in reply to Jamie22)
       Post #: 2
RE: High idle problem - 6/27/2008 12:27:16 AM
Jamie22
Status: offline
Nah all thats is done that was the first thing I checked. Carb can completely closed and still idles high as hell lol...
WWW.BADRC.COM
(in reply to rebelracer246)
       Post #: 3
RE: High idle problem - 6/27/2008 12:28:57 AM
Jamie22
Status: offline
Nice lookin track btw
< Message edited by Jamie22 -- 6/27/2008 12:29:10 AM >
WWW.BADRC.COM
       Post #: 4
RE: High idle problem - 6/27/2008 12:30:43 AM
rebelracer246
Status: offline
thanks do you have a return spring ??
       Post #: 5
RE: High idle problem - 6/27/2008 12:32:56 AM
slayerphonics
Status: offline
Does it idle real high after a high speed run then eventually idle down?
That could be a lean high speed,
How much space is there between the slide and the inside of the carb? should be about the width of a credit card or so.
If thats set right, its gotta be your tune,
You could have used the low speed needle at one point to compensate for an incorrect idle? or vice versa.
Id check the gap,
Then reset my needles and tune the high speed then the low speed.
There's a right way and wrong way to do everything and the wrong way is trying to make everybody else do it the right way
       Post #: 6
RE: High idle problem - 6/27/2008 12:33:57 AM
Jamie22
Status: offline
No linkage workin great. Can put my vspec on there and it idles just fine.
WWW.BADRC.COM
       Post #: 7
RE: High idle problem - 6/27/2008 12:35:20 AM
Jamie22
Status: offline
Yea the gap looks good. Check the low speed needle to and it didnt change anything. Wouldnt an air leak make it idle high ?
WWW.BADRC.COM
(in reply to slayerphonics)
       Post #: 8
RE: High idle problem - 6/27/2008 12:36:23 AM
rebelracer246
Status: offline
hum it might be your low speed that has some to do with your idle also try riching it up and hour and riching up your idle 4 hours
       Post #: 9
RE: High idle problem - 6/27/2008 12:39:53 AM
Jamie22
Status: offline
Aight thanks for the info will give it a try tomarrow
WWW.BADRC.COM
       Post #: 10
RE: High idle problem - 6/27/2008 12:41:50 AM
rebelracer246
Status: offline
no problem i had trouble with that on my sportworks .26 v2 and i riched up the low speed and it went down
       Post #: 11
RE: High idle problem - 6/27/2008 12:42:35 AM
Jamie22
Status: offline
Yea i still amazed on how much power this motor has lol
WWW.BADRC.COM
       Post #: 12
RE: High idle problem - 6/27/2008 12:44:33 AM
rebelracer246
Status: offline
yep they have power but sometime they can be hard to tune lol
       Post #: 13
RE: High idle problem - 6/27/2008 12:47:34 AM
Jamie22
Status: offline
Yea and hard to keep the tires mounted on
WWW.BADRC.COM
       Post #: 14
RE: High idle problem - 6/27/2008 12:49:47 AM
rebelracer246
Status: offline
ya thats why you richin the high speed so you can keep them mounted lol
       Post #: 15
RE: High idle problem - 6/27/2008 2:17:41 AM
nascardad24
Status: offline
quote:
ORIGINAL: rebelracer246
Yes, give the low end a few hours, it will bring the idel down. Dont run it to lean on the low end, bad things happen to a nitro engine when the low ends to lean.
Kyosho STRR~Futaba~Sirio~Acer Racing~BCE~
Horsepower sells engines, Torque wins races
       Post #: 16
RE: High idle problem - 6/29/2008 3:52:44 PM
Jamie22
Status: offline
Well got to run the truggy yesterday took the low end back out to factory specs and still idles high
WWW.BADRC.COM
(in reply to nascardad24)
