rclugnut10
VT, USA Status: offline
quote:
ORIGINAL: Revomad1 quote:
ORIGINAL: BudBud You might try turning the fuel nipple on your carb so that it pints between the air cleaner and the head, then running your fuel line from the tank the same way. It will not run as long upside down, but it will go a long ways towards slowing down the half tank lean issue. I started doing that about six months ago and it really seems to help with that. You have a nice stout looking truck there. I am guessing you have your antenna in fuel line routed around the chassis so you do not tear it off. I just had a runaway this week, first time with a Savage. The antenna wire snapped off about two inches from the rx. It was kind of a helpess sick feeling watching it run in a big arc out of the park, onto the street, back into the park across another street, across two yards, then climb a chainlink fence and flip over on its lid. I never was a fail safe guy, but I am seriously thinking about getting a few now. BB Thanks for the tip. I might have to try routing my fuel tubing that way. Yeah my antenna is in the tubing zip tied to the roll bar. It's a 2.4ghz antenna, so it's only about 5-6 inches long. I kept snapping plastic tubes, so I settled on this set-up. It's nice to be able to keep the antenna under the body for appearance purposes. the DTX WILL hold up to anything, and if you want cut short for appreances you can, + you get better range if your antenna is vert rclugnut10
_____________________________
HPI SAVAGE X SS DTX EVADER PRO + SIDEWINDER 4600
