HaveBlue
Joined: 1/3/2005 From: Sydney, AUSTRALIA Status: offline
I found the same issue as you raise mojave, I have the hydros on the front of my FG onroad but re-installed cables to the rear..most will say that hydros are good all round , but I use the cabled rear , because of the adjustment advantage so if I hit the brake really hard I can flick the rear around on a tight hair pin . whilst I can handle the corners fine with full hydros, I like how the back end slides into it and flicks around the corner
< Message edited by HaveBlue -- 6/28/2008 2:36:02 AM >
_____________________________
if your still in control....you aint goin fast enough **Revver Bro 95**
