Jato with traxxas dish 2.2 HELP!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> Jato with traxxas dish 2.2 HELP!
Page: [1]
Login
Jato with traxxas dish 2.2 HELP! - 6/27/2008 7:06:36 PM
mbz300sdl
Status: offline
Ok i have a Jato 2.5 and finally got around to getting the 2.2 dish wheels for it mounted and glued the new tires and i put the rear wheels on everything is fine. I put the fronts on and go to tighten the nut and the axle shafts are too long!!! Why do these not fit when it says right on the Jato parts list that they fit the Jato? Is there a different axle i need to buy or a certain spacer?
Thanks in advance.
       Post #: 1
RE: Jato with traxxas dish 2.2 HELP! - 6/27/2008 7:16:48 PM
nitrosport963
Status: offline
better to long then to short
(in reply to mbz300sdl)
       Post #: 2
RE: Jato with traxxas dish 2.2 HELP! - 6/27/2008 7:28:01 PM
robbio4422
Status: online
do you have a measurment?
_____________________________
my gt brings all the girls to my yard
(in reply to nitrosport963)
       Post #: 3
RE: Jato with traxxas dish 2.2 HELP! - 6/27/2008 7:28:21 PM
mbz300sdl
Status: offline
True
but i was hoping there is something other than well add a washer that i can replace like a correct length axle.
       Post #: 4
RE: Jato with traxxas dish 2.2 HELP! - 6/27/2008 7:30:49 PM
mbz300sdl
Status: offline
quote:
ORIGINAL: robbio4422
no but i will get one
i tired putting an extra bearing to take up the space but then they bind and wont roll freely
(in reply to robbio4422)
       Post #: 5
RE: Jato with traxxas dish 2.2 HELP! - 6/27/2008 7:36:14 PM
robbio4422
Status: online
well cutting could be an option.. but it depends on how long it is and how long you need it to be... if you have enough threads to be able to cut a bit off that might work... got a dremal tool? if you do go that rout then make sure you have the nut on the axle befor you cut it... then pull the nut off after you cut and it should "re-thread" it, just be carefull while cutting and keep it clean
       Post #: 6
RE: Jato with traxxas dish 2.2 HELP! - 6/27/2008 8:06:00 PM
motorhead91
Status: offline
you have the stock axles right?
make sure you have both bearings in and the spacer, and tighten the nut all the way down.....
it will be fine, i've run mine like that for a year
Chuck Norris Doesn't Have To Write Books. The Words Assemble Themselves In Fear.
       Post #: 7
RE: Jato with traxxas dish 2.2 HELP! - 6/27/2008 8:11:52 PM
robbio4422
Status: online
quote:
ORIGINAL: motorhead91
lol ya... depending on how much extra there is... attatch some razor blades to the extra and you have a "battle" truck! pump to pass!
(in reply to motorhead91)
       Post #: 8
RE: Jato with traxxas dish 2.2 HELP! - 6/27/2008 8:12:53 PM
robbio4422
Status: online
sorry... im sitting in class (graphic animation) and had a crazy idea for a cartoon.. had to toss that out there! my imagination runs wild
       Post #: 9
RE: Jato with traxxas dish 2.2 HELP! - 6/27/2008 8:23:23 PM
pieky22
Status: offline
i think what he is saying is that he doesnt have enough threads on the shaft to tighten down the wheel properly so he has to put washers on the unthreaded shaft to take up the extra space. anyways, i cant really think of anything. one thing u might try is using nitro ruster or stampede front axles. thats is all that i can think of...good luck, and by the way what wheels are these so i can steer clear of them?
92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
       Post #: 10
RE: Jato with traxxas dish 2.2 HELP! - 6/27/2008 11:12:35 PM
Mekong
Status: offline
I got the same wheels, same problem.
On these dish front wheels there is no need for the metal spacer between the bearings that is stock on the stock front wheels. So what I did was put the spacer on the axle first and then the wheel with bearings. That spacer adds just enough to thread the nut on all the way. Works great for me.
< Message edited by Mekong -- 6/27/2008 11:13:09 PM >
MM5700 Pede & Jato 3.3, and some others...
(in reply to pieky22)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.578RCU1
