My car starts but I cannot keep it running?
Tower Hobbies
Logged in as Guest
  Printable Version
Team Losi Muggy - RTR
Seller:  PastorVee
Details:   $1,100.00   |  10/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> My car starts but I cannot keep it running?
Page: [1]
Login
My car starts but I cannot keep it running? - 6/28/2008 8:51:09 PM
rcman6
Status: offline
i changed from 20% fuel to 30% fuel and now my car wont start. I changed the glow plug and went back to factory settings and it still wont run what do i do?
       Post #: 1
RE: My car starts but I cannot keep it running? - 6/29/2008 3:31:43 AM
jerodp71
Status: offline
If it wont stay running try leaning your hsn then your lsn and finally adjust your idle. Hope this helps! Good luck.
(in reply to rcman6)
       Post #: 2
RE: My car starts but I cannot keep it running? - 6/29/2008 3:44:09 AM
rebelracer246
Status: offline
take your engine back to the factory settings and tune from there you will be able to get it quicker that way
_____________________________
http://www.youtube.com/watch?v=B6nJCigwtps
(in reply to jerodp71)
       Post #: 3
RE: My car starts but I cannot keep it running? - 6/29/2008 1:58:34 PM
TeeKuang
Status: offline
I have a question for you,
1. How old is your engine? how many liters of fuel has been through?
2. Can you turn your engine flywheel without effort?
3. What engine are u running? you need to shim shim it up?
4. is the fuel fresh?
-GS CL1 Buggy
-HoBao Hyper ST Pro
(in reply to rebelracer246)
       Post #: 4
RE: My car starts but I cannot keep it running? - 6/30/2008 8:52:08 PM
rcman6
Status: offline
new fuel is in it and it is an 8ight t.about 2 months old about 1 1/2 gallons of 20% and about a tank of 30%
(in reply to TeeKuang)
       Post #: 5
RE: My car starts but I cannot keep it running? - 7/1/2008 11:04:00 PM
motoman827
Status: offline
Pull the glow plug out and connect your igniter to it and make sure it is glowing bright orange. If it is OK, go back to your settings that you used with the 20% and try the 20% to make sure nothing is wrong with your engine. If it starts, then you know the needles need to be adjusted or the head may need a different shim. Find out from the manufacturer if you need to change the head shim when using 30% fuel.
Caster Racing K8T, ZX1-R
Hurricane XP
       Post #: 6
RE: My car starts but I cannot keep it running? - 7/1/2008 11:38:29 PM
rcman6
Status: offline
well i found out that my glow starter was out.
(in reply to motoman827)
       Post #: 7
RE: My car starts but I cannot keep it running? - 7/2/2008 2:31:33 AM
rcman6
Status: offline
now my car is hard to start it started for a second and when it was sitting there the wheels wer turning really fast and then it just quit and now when i try to start it it with the roto start the roto will jerk i thot it was fluded but it is not.
       Post #: 8
RE: My car starts but I cannot keep it running? - 7/2/2008 3:29:43 AM
motoman827
Status: offline
You need to go back when it was working with the 20% fuel. If it's sitting there and the wheels are turning fast, either the idle screw is turned too high, the controller throttle trim is too high, or the carb is adjusted lean.
Adjust the idle screw first with the throttle fully closed. There should be about .08mm space. Then adjust the LSN and HSN screws to factory setting which should be on the rich side. When you turn the controller and car on and the throttle trim is in the neutral position, the carb should be closed to the .08 setting. Now you can open the carb slightly with the throttle trim just to get it started. After it runs for about 20 - 30 seconds, close the controller throttle trim back to its neutral setting. If the idle is too high or too low after it warms up, adjust the idle screw to get a good idle. Adjust your HSN first, then LSN to get it running good.
Hurricane XP
       Post #: 9
RE: My car starts but I cannot keep it running? - 7/2/2008 3:59:53 AM
youwish16
Status: offline
what motor is it? did you shim it for 30%? if the motor is originally shimmed for 20%, you'll have to add another shim.
if it is shimmed for 20% and you dont add another shim before using 30%, you rish screwing the motor up
< Message edited by youwish16 -- 7/2/2008 4:00:41 AM >
Losi 8ight w/ RB S3II L2G,Avid Bearings,Dynamite Clutch Shoes & Pipe,Sprektrum Radio,Ace Servos,Team Sidewinder,Bad Horsie
       Post #: 10
RE: My car starts but I cannot keep it running? - 7/2/2008 7:01:25 AM
rcman6
Status: offline
which shim should i get?
(in reply to youwish16)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
