KidEpoxy
TX, USA Status: offline
The motors are not the limit of the power for the 1/2a conversion, but how much you want to spend on the battery to feed enough juice to the 2oz motor. It is not hard to find a 150w-200w brushless in the 1.8-2.8oz weight class but how many amps the battery can suply is what controls the weight of the battery. Unlike a fuel tank, where 2oz fuel flys twice as long at the same power as 1oz of fuel, the battery size determines how much power it can deliver as well as how long you can fly at that power. A cheap battery to deliver 15amps would be a 10c 1500mili amp hour, but an expensive batt for the same 15amps of power might be a 20c 750 mha, or even more costly a 30c 500mah. All make the motor turn with the same strength & speed, but the high discharge 30c batt would be much smaller & lighter & cost-a-lot-er.... in addition to running out of steam in mush less time.
_____________________________
Optional MA is part of AMA history, we can go optional AGAIN if we just say so
