New Planes Available Curare II Ect.......
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> New Planes Available Curare II Ect.......
Page: [1]
Login
New Planes Available Curare II Ect....... - 6/29/2008 3:41:46 AM
rv7driver
Status: online
New planes, ARC and ARF Curare II, Atlas, Compensator, and I think the Astro-Hog. They give SPA Discounts also.
www. Pyramidhobbies.com
I am not affiliated with this organazation, just ran across them and thought I'd pass this along to anybody interested.
Pete
_____________________________
the old saying in aviation is keep the dirty side down!; how Boring!
       Post #: 1
RE: New Planes Available Curare II Ect....... - 6/29/2008 6:42:40 AM
rainedave
Status: online
Thanks Pete. I'm not familiar with the Curare II. I didn't even know Prettner designed a Mk II version. What is its history?
David
(in reply to rv7driver)
       Post #: 2
RE: New Planes Available Curare II Ect....... - 6/29/2008 12:27:26 PM
Free Bird
Status: offline
I just took a look, interesting stuff. I wonder what the power setup in in the Curare II, as it's done as an electric.
FB
(in reply to rainedave)
       Post #: 3
RE: New Planes Available Curare II Ect....... - 6/29/2008 1:24:05 PM
rv7driver
Status: online
From what I understand, you can have them build to it anyway you want, ie; four stroke two stroke or electric just tell them before they build it. Dave I don't know about the Curare MK II I did not know their was a MK II either. I'm sure those guys can answer your Question.
I noticed you can have a foam wing or built up. Made in the good ole USA!!!!!
Pete
(in reply to Free Bird)
       Post #: 4
RE: New Planes Available Curare II Ect....... - 6/29/2008 1:46:29 PM
Lotus72D
Status: offline
quote:
ORIGINAL: rainedave
David
Judging by the photos the 'II' is what they're calling a Prettner Curare that's been give the "SPA treatment"...converted to a fixed gear tail dragger with the fuse possibly stretched slightly to offset the weight of a 91 4 cycle.
Looks like I can get a set of cores and short kit for an Atlas so I'll have found my next project!
       Post #: 5
RE: New Planes Available Curare II Ect....... - 6/29/2008 2:13:57 PM
rainedave
Status: online
Isn't it cool that there are now a lot more kits available for classic pattern than there are for current 2M pattern? I only know of a couple of 2M kits: MHester's Black Magic series and the CAModels kits. There may be more that I don't know of, but almost all 2M planes are either ARCs or ARFs. I think this validates what I perceived two years ago when I found this forum, that, people in to classic pattern are in to building.
David
(in reply to Lotus72D)
       Post #: 6
RE: New Planes Available Curare II Ect....... - 6/29/2008 7:30:37 PM
alcarafa
Status: offline
A tail dragger Curare ? hmmmmm well I'll name it "DAS UGLY CURARE" l like tricycle's better thats why they are classics.
Rafa
       Post #: 7
RE: New Planes Available Curare II Ect....... - 6/29/2008 8:05:53 PM
BTerry
Status: offline
quote:
ORIGINAL: rainedave
David
Dave, don't forget the Insight and Pentathlon...
Point taken.
       Post #: 8
RE: New Planes Available Curare II Ect....... - 6/30/2008 1:08:20 AM
Fxrs_tim
Status: offline
quote:
ORIGINAL: alcarafa
I'm with ya on that one. Fixed gear taildragger?! That thing is FUGLY.
(in reply to alcarafa)
       Post #: 9
RE: New Planes Available Curare II Ect....... - 6/30/2008 3:22:11 AM
Roary m
Status: offline
Wouldn't take much I would think to just toss the gear and put in retract trike gear. I assume this is an arf. Other than the gear he looks like the real thing.
(in reply to Fxrs_tim)
       Post #: 10
RE: New Planes Available Curare II Ect....... - 6/30/2008 12:32:49 PM
Ron King
Status: offline
quote:
ORIGINAL: rainedave
David
Those of us who were doing this thirty years ago had no choice. If you wanted a pattern plane, you designed your own or got the kit and built it. All of my early pattern planes were designed around the Kaos wing and all were capable of much more than the pilot could deliver. Then I moved on to vacuum covered foam wings w/glass fuselages and my planes looked nicer and still flew better than the pilot.
While I do like the convenience of today's ARFs, there is something very satisfying about building and flying my own model.
Ron
       Post #: 11
RE: New Planes Available Curare II Ect....... - 6/30/2008 12:52:28 PM
Atlanta 60
Status: online
Thanks to all the guys who are making kits for us!! You know none of them are getting rich doing it...It's allot more a Labor of Love than anything else...
For me..Building is 1/2 the Fun!!
Chuck
"A Superior Pilot uses his Superior Judgment to avoid using his Superior Skills." - astronaut Frank Borman
(in reply to Ron King)
       Post #: 12
RE: New Planes Available Curare II Ect....... - 6/30/2008 12:56:34 PM
Skylane
Status: offline
Actually, these planes are made by Sid Austin and his crew at Pyramid Hobbies. You can order them with retracts if you want and you can specify the type of engine and the mounting orientation. The Curare II shown on the web site is electric powered using readily available off the shelf components. Sid flew it at the Atlanta SPA contest earlier this month.
Jeff
Skylane N9214G
SPA 243
(in reply to Roary m)
       Post #: 13
RE: New Planes Available Curare II Ect....... - 6/30/2008 1:17:02 PM
rv7driver
Status: online
Dug out my SPA news letter, Sid's Curare is set up with the following electric's: stock E-Flite 60 with 15/8thin blade prop,Phoenix 80 speed controller and thunder-power 6 cell 3850 MAHpower pack. says he gets 14 minutes flight. he did fly it @ hotlanta SPA contest on 7 and 8 of june. I was not in town so I did not see it fly.
I am not in to electric's so thats all I can tell you about it. He does offer ARC and ARF kits, I'm looking @ the ARC Atlas for retracts.
Pete
< Message edited by rv7driver -- 6/30/2008 1:18:54 PM >
       Post #: 14
RE: New Planes Available Curare II Ect....... - 6/30/2008 1:43:44 PM
bob27s
Status: offline
Those look like nice airframes......
<soapbox> But its just not right to see either the Curare or Compesator as a tail-dragger or with a 4-C up front !! Cringgge... </soapbox>
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
