KBV/ BVM ENGINES
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> KBV/ BVM ENGINES
Page: [1]
Login
KBV/ BVM ENGINES - 6/29/2008 4:44:48 PM
Captin1
Status: offline
Who fixes them or were can I get some parts for 82 engines
       Post #: 1
RE: KBV/ BVM ENGINES - 6/29/2008 5:45:11 PM
w8ye
Status: online
You can get rings from Frank Bowman. Frank can also do the whole job for you.
Frank C Bowman
1211 N Allen Ave
Farmington, NM 87401-3568
505-327-0696
ringmaster46@msn.com
Bill Jenson will do the work for you.
Bill Jensen
51 Hillside Dr.
Beacon Falls, CT 06403
203 888 4819
WBillJensen@cs.com
www.bj-model-engines.com
And Bearings from Boca Bearings or R/C Bearings but you will have to see which bearings are in your engine.
http://www.bocabearings.com/main1.aspx?p=quicksearchkit&cat=2
http://www.rc-bearings.com/
If you have a bad cylinder wall - this guy can rechrome your cylinder
Blackburn Aero Engineering
P O Box 15143
Amarillo, Texas 79105
(806) 622-1657
Blkbrnaero@aol.com
This guy specializes in engine restoration work
Walt Craig
3664 Smoketown Road
Glenville, PA 17329
Walter.craig@Carlisle.army.mil.
< Message edited by w8ye -- 6/29/2008 6:00:02 PM >
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to Captin1)
       Post #: 2
RE: KBV/ BVM ENGINES - 6/30/2008 3:37:06 AM
proptop
Status: offline
mecoa still has a few parts as well...
www.mecoa.com
https://shop.mecoa.com/shopdisplayproducts.asp?id=167
< Message edited by proptop -- 6/30/2008 3:46:38 AM >
It's bad luck to be superstitious...
Revver Bro #77
(in reply to w8ye)
       Post #: 3
RE: KBV/ BVM ENGINES - 6/30/2008 3:28:34 PM
JeffH
Status: offline
I am not sure how many parts were the same from the KBV .82s and the K&B .82s. I think Bob ran his own carb design and his own piston and sleeve design. I am not sure about that, but it does stick in my brain for some reason. The KBVs always ran better than the K&Bs did, that is for certain.
Jeff
(in reply to proptop)
       Post #: 4
RE: KBV/ BVM ENGINES - 7/3/2008 6:37:11 PM
lfinney
Status: offline
you have abc engine, at most unless run very hard, you will need at most a set of bearings get some good ones with plastic cages, and take a look at your rod, make sure its ok, contact macs products for a header and pipe setup, they have tons of knowledge about bvm and K&B engines
(in reply to JeffH)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.516RCU1
