bhcvc
CA, USA Status: offline
The standard seems to use inrunner BL motors for conversions...for trucks, typically in the range of 2000kV to 5700kV. Most people seem to use enough voltage to operate the motor in the 30k to 50k rpm range. However, I've seen quite a few people use low kV (i.e. 500-600kV) outrunner motors for truggy and buggy conversions. They seem quite fast also, but with the same battery setup, the kV is MUCH lower, but the people that have done the conversion said it's ok because it's direct drive (no tranny) in truggies/buggies. So, here's an example...assume a 1/8 truggy of any sort, no tranny, center diff only: 2200kV BL INrunner motor running 2s2p 14.8V = 32560rpm 600kV BL OUTrunner motor running 2s2p 14.8V = 8880rpm Just doesn't seem like the Outrunner motor would be fast enough relative to the Inrunner setup, but people with Outrunners claim the same speeds (about 45mph). How is this possible? Which setup is correct or better? I'm looking to do an electric truggy conversion and would really like to know which setup to get. Thanks.
