dondecap
Joined: 5/19/2008 From: BRISTOL, CITY of BRISTOL, UNITED KINGDOM Status: offline
hi frostman55 the main blades should rotate clockwise looking down on them, if they dont just turn the plug round in the 4 in 1, the green light in the 4 in 1 is right, the red is just to show that it is recieving max signal from transmitter. some blades although seem ok give no lift, try another pair, they should be ballanced - assemble them onto head [off heli] then place onto two glasses resting on the ball section, they should hold level. if not use sellotape at ends to get the lighter[higher] blade back to horazontl. then refit to heli, put heavy wieght though skids and spin up to just undr 50% throttle, look from side of heli at ends of blades they should both be in the same plane or within 1mm if not then they need to be lifted slightly [the lower one] with tape under the front edge at screw - this is tracking, very important on fixed pitch, also any vibration at head needs to be sorted check that flybar paddles are flat with control frame- square at head moves with flybar - and exactly same length, the heli will have a tendency to tip left on takeoff, dont be too cautious, once slightly 'light' give quick punch of throttle to get a foot or so up then helli should settle again, this bird wont just sit there hovering you will need to work at it to keep it in one place even indoors, -does not realy like any wind!!!- but good fun learner bird, fly this you can fly most. swash plate - where servo control links go to- should be 90 degress to mast front and side, to help eliminate the left flight on takeoff you could give 1/2 turn longer on swash link after it is level, thats the link on the side not the front [1/2 turn longer]. also turn rotor so that flybar is out left and right on heli and lift by bar , heli should hold with tail boom horazontal if not move battery to get level. hope this helps regards don
