need help with repair
Tower Hobbies
Logged in as Guest
  Printable Version
PARK ZONE F-4U CORSAIR
Seller:  harleydoberman
Details:   $279.99   |  8/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Crash & Rebuild >> need help with repair
Page: [1]
Login
need help with repair - 6/30/2008 5:55:17 AM
cupydofwyldfyre
Status: offline
i have a plane that's like a low wing avistar but more sport like.... any i repaired the plane after minor damagw the got it airborne but ona good landing the nose wheel folded when it tipped the grass.... how can i repair that? do i have to take the whole firewall out or put another piece of wood over it?
Kelvin
       Post #: 1
RE: need help with repair - 6/30/2008 6:37:29 AM
Adui
Status: offline
How is the nose wheel attached?? Does it have a bracket or is it directly into the wood? Mine is in a bracket)
A picture would help considerably.
_____________________________
Chance favors the prepared mind. ~Louis Pasteur~
(in reply to cupydofwyldfyre)
       Post #: 2
RE: need help with repair - 6/30/2008 7:49:06 AM
flyX
Status: offline
I'd epoxy another piece of wood behind the firewall and use longer screws. Then glue back the piece that's been ripped
or cut a nice square to replace the ripped out section to make it look cleaner or so the bracket will mount flush.
another option is to get another engine mount with nose wheel holes in them.
Never the less I'd re enforce the firewall either way.
< Message edited by flyX -- 6/30/2008 7:50:56 AM >
(in reply to Adui)
       Post #: 3
RE: need help with repair - 7/1/2008 5:42:39 AM
milldwg
Status: offline
they sell engine mounts that can hold ur front wheel easily but it sounds As if u will have to re enforce the frontend\nose
(in reply to flyX)
       Post #: 4
RE: need help with repair - 7/7/2008 1:26:42 PM
Nehru
Status: offline
I would advice you to support the fire wall with 8 triangular gussets with epoxy to the inside of the fuselage. If you can draw the diagram I will be able to tell you exactly what to do.
Nehru
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.482RCU1
