Homelite Classic 200 saw-Needle bearings
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> Homelite Classic 200 saw-Needle bearings
Page: [1]
Login
Homelite Classic 200 saw-Needle bearings - 6/30/2008 2:49:40 PM
frenchie79
Status: offline
I don't know what cc this is, it has needle bearings for crank support. Is this considered a poor choice for conversion???
Click to see fullsize image.
Click for fullsize
< Message edited by frenchie79 -- 6/30/2008 2:50:31 PM >
_____________________________
Frenchie #193
       Post #: 1
RE: Homelite Classic 200 saw-Needle bearings - 6/30/2008 4:16:48 PM
captinjohn
Status: offline
I had one given to me...like new... ran good, but the prop danced all over the place. I suppose a thrust washer installed or a ball bearing placed in some how may help. Good luck Capt,n
I never met a engine I did not like!
(in reply to frenchie79)
       Post #: 2
RE: Homelite Classic 200 saw-Needle bearings - 6/30/2008 5:26:05 PM
frenchie79
Status: offline
Are needle bearings considered a bad omen for these applications. What cc is this? The saw said Homelite 200 classic?
Frenchie #193
(in reply to captinjohn)
       Post #: 3
RE: Homelite Classic 200 saw-Needle bearings - 6/30/2008 7:03:45 PM
av8tor1977
Status: offline
If/when I run across one of these needle bearing engines, I just move on to another. In general, engines are so cheap and easy to come by usually, that it's just not worth messing with one that needs a lot of work or is less than desireable in some manner.
If you really need to use the engine for some reason, you could probably rig some brass shims to take the end thrust. A neater solution would be to use a Torrington bearing. A Torrington bearing is like a 3 piece washer assembly, with the center washer having roller bearings. They make a really nice thrust bearing, but you would probably have to machine the case and/or the crank to make room for one. Might have to do that for a brass shim as well....
AV8TOR
If it's not scary, it's NOWHERE NEAR powerful enough!!
       Post #: 4
RE: Homelite Classic 200 saw-Needle bearings - 6/30/2008 7:10:53 PM
frenchie79
Status: offline
Av8tor-Thanks, I don't need the engine, just playing. Going to go through 20 of these till i fine a few that would make good engines without extensive work or expense. I have another engine off a craftsman weed trimmer-says 26cc. Could you ID it for me.
Click for fullsize
Frenchie #193
(in reply to av8tor1977)
       Post #: 5
RE: Homelite Classic 200 saw-Needle bearings - 7/14/2008 3:50:27 AM
captinjohn
Status: offline
I do not think the last phot of a engine is a homelite!!! not Sure. Capt,n
       Post #: 6
RE: Homelite Classic 200 saw-Needle bearings - 7/14/2008 2:41:47 PM
Antique
Status: offline
Needle bearings work fine. If you have the proper thickness thrust washer they will run for years. Look at Quadras.
       Post #: 7
RE: Homelite Classic 200 saw-Needle bearings - 7/14/2008 3:02:25 PM
frenchie79
Status: offline
Look at the first picture, shows two brass washers that are pretty hefty. What do you think?
Frenchie #193
(in reply to Antique)
       Post #: 8
RE: Homelite Classic 200 saw-Needle bearings - 7/15/2008 3:37:48 AM
captinjohn
Status: offline
I think if you run it and the prop keeps a strait arc and the crankshaft does not seem to float all over....it should be ok. I would rather have ball bearings any day. Capt,n
       Post #: 9
RE: Homelite Classic 200 saw-Needle bearings - 7/15/2008 2:28:28 PM
Antique
Status: offline
No question that ball bearings are the best, but needle bearings with the proper thrust bearing have been used in our model engines for many years.....
       Post #: 10
RE: Homelite Classic 200 saw-Needle bearings - 7/15/2008 3:51:08 PM
frenchie79
Status: offline
Look at the picture in the first post-Do they look like enough?????????
Frenchie #193
       Post #: 11
RE: Homelite Classic 200 saw-Needle bearings - 7/15/2008 5:19:00 PM
captinjohn
Status: offline
OK...I looked at the photo.....looks ok...but it is the amount of "slop" that counts when put together. How much end play do you have? If not much...run the engine with a prop on it. That is very easy to do test. Best Regards Capt,n
       Post #: 12
RE: Homelite Classic 200 saw-Needle bearings - 8/21/2008 9:00:48 AM
KeithLuneau
Status: offline
That looks just like the one I took out of an old XL saw. Mine is a 26.2cc, but there's also one that looks very similar and is a little larger. I had a thread back in 2004 I think, where someone explained how to determine which one it is. I ran mine for a while on an airboat, and am currently in the process of putting it on a Four Star 120. Actually the plane is done, just waiting on the servos to arrive and I can get it finished up and flying! I do have a bit of slop (less than 1/16" , but the crank doesn't seem to float at all when it's running, I've had no problems at all. Mine had a twin needle Walbro carb on it, not sure what size, but the intake is marked "28". I don't have a tach, but I know it seems to spin a 16x8 just fine. It runs great, and I haven't had to touch the needles in the 4 years I've had it running in the boat!
Here's a picture of the plane. One thing to keep in mind too, is the odd angle of the carb makes for some extra challenges when mounting the engine and hooking up a throttle cable.
Click for fullsize
Click for fullsize
       Post #: 13
RE: Homelite Classic 200 saw-Needle bearings - 8/21/2008 11:09:37 AM
KeithLuneau
Status: offline
Here is another thread with some good info, as well as info on how to tell which size engine you've got...
http://www.rcuniverse.com/forum/m_3352385/anchors_3354386/mpage_1/key_Walbro%252CHDC/anchor/tm.htm#3354386
(in reply to KeithLuneau)
       Post #: 14
RE: Homelite Classic 200 saw-Needle bearings - 8/21/2008 7:17:15 PM
frenchie79
Status: offline
Interesting-thanks. I sidelined that engine for others that make better conversions, but it is on the shelf for one day. I'm am going to check the bore just to see what i got.
Frenchie #193
       Post #: 15
RE: Homelite Classic 200 saw-Needle bearings - 8/22/2008 1:01:47 AM
KeithLuneau
Status: offline
By the way, I was reading about the engine some more last night after searching for that thread. The HDC carbs that came on these are supposedly pretty good, and a bit larger than what's standard on most newer engines. I know I looked at mine and it's got the original HDC-65 carb on it, and it's quite a bit larger than all the other Walbro's I've got here. Nice to know!
By the way here's the thread I started when I did mine. It may have some other useful info as well.
http://www.rcuniverse.com/forum/m_1998937/anchors_1998937/mpage_1/key_Homelite%252CChainsaw/anchor/tm.htm#1998937
< Message edited by KeithLuneau -- 8/22/2008 1:22:31 AM >
       Post #: 16
