Volcano SV Pro Steering Servo    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Volcano SV Pro Steering Servo
Page: [1]
Login
Volcano SV Pro Steering Servo - 6/30/2008 6:16 PM
JAMBF750
Score: 100
Last Login: 1/16/2012
Status: offline
Need a little help. Just yesterday (after a medium size crash) my steering servo stopped working. I changed the truck battery thinking this may have been the issue because it began only turning in one direction, but after I changed out the battery, it wouldn’t work at all. I tried 3 different hump batteries, so I know this is not the issue, plus they all operate the throttle servo with no issues perfectly. The steering servo won’t move in either direction now, almost like power is not getting to it or it simply stopped working. Do they go bad? Any suggestions as to what may have happened? If I need to change the servo, should I upgrade the part?
As Always,
JAM
Hide Signatures
       Post #: 1
RE: Volcano SV Pro Steering Servo - 6/30/2008 6:55 PM
Syclone354
Score: 100
Last Login: 12/29/2012
Status: offline
did you reseat the connectors in the receiver? Maybe they came loose. If not, its probably a bad servo. They do go bad, i just replaced the steering servo in my avalanche last week. Spend the extra money and get a good high torque servo for the steering side it does make a difference.
_____________________________
Redcat Avalanche
Redcat Tsunami
Hide Signatures
(in reply to JAMBF750)
       Post #: 2
RE: Volcano SV Pro Steering Servo - 6/30/2008 7:00 PM
greasemonkeyfred
Score: 100
Last Login: 10/14/2011
Status: offline
I had the exact same problem and I had to replace it. Do a quick test on the receiver unplug the throttle servo and plug in the steering servo in its spot .then see if it steers when you hit the gas or brake .IF it works then try it back in its spot ,if it doesnt then you need new servo.
Hide Signatures
       Post #: 3
JAMBF750
Score: 100
Status: offline
I don't mind spending the money for a better servo, I just need to know what will fit. I will try and do a serch, but if anyone knows what servo to buy for the volcano SV Pro, kindly let me know.
Hide Signatures
(in reply to Syclone354)
       Post #: 4
RE: Volcano SV Pro Steering Servo - 6/30/2008 7:02 PM
JAMBF750
Score: 100
Status: offline
quote:
ORIGINAL: greasemonkeyfred
Good idea, I will try this later today.
Hide Signatures
(in reply to greasemonkeyfred)
       Post #: 5
RE: Volcano SV Pro Steering Servo - 6/30/2008 7:09 PM
Syclone354
Score: 100
Status: offline
I think servos are pretty universal, if you go to a LHS and ask for a high torque steering servo they will have what you need.
Redcat Avalanche
Redcat Tsunami
Hide Signatures
       Post #: 6
RE: Volcano SV Pro Steering Servo - 6/30/2008 11:33 PM
JAMBF750
Score: 100
Status: offline
I think I will order the FUTABA S3003 unless someone thinks it wont work. It couldnt hurt to have it incase the other servo is OK and there is another issue.
JAM
Hide Signatures
       Post #: 7
RE: Volcano SV Pro Steering Servo - 7/1/2008 5:45 AM
Gelo_USA
Score: 100
Last Login: 7/30/2009
Status: offline
I have the s3003... I personally dnt like it... I use it jst because I have no other one and still havent had time to get another one in... the stock one on the volcano is better than the s3003... I would go to the local hobby shop and ask them for a high torque servo....
Hide Signatures
       Post #: 8
RE: Volcano SV Pro Steering Servo - 7/1/2008 6:23 PM
JAMBF750
Score: 100
Status: offline
quote:
ORIGINAL: Gelo_USA
I did a little research last night and discovered the same thing. I have a Hitec HS645MG (Metal Gear) that I was going to use in another larger truck, but will use it in the Volcano instead. It should work great.
Hide Signatures
(in reply to Gelo_USA)
       Post #: 9
RE: Volcano SV Pro Steering Servo - 7/1/2008 6:40 PM
a4d2a0m
Score: 100
Last Login: 4/2/2010
Status: offline
I changed mine to a mg995 off ebay. It was only $12. All metal gears, two ball bearings, high speed/high torque....works great!
Hide Signatures
       Post #: 10
RE: Volcano SV Pro Steering Servo - 7/1/2008 9:31 PM
JAMBF750
Score: 100
Status: offline
quote:
ORIGINAL: a4d2a0m
That was great advice...I just won one on eBay for $1.00 and it cost $13.99 to ship. Seem like a real nice servo. Thanks
Hide Signatures
(in reply to a4d2a0m)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.375RCU1
