Question about O.S. 46 AX carb
Tower Hobbies
Logged in as Guest
  Printable Version
NIB O.S. Engines O.S. .91 SZ-H PS-Hyper - RTF
Seller:  mkranitz
Details:   $339.00   |  10/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> O.S. Engines Support >> Question about O.S. 46 AX carb
Page: [1]
Login
Question about O.S. 46 AX carb - 6/30/2008 7:31:03 PM
mjfrederick
Status: offline
I purchased a new OS 46 AX from my local hobby shop over the weekend. I didn't realize until after I got home that the remote needle valve, while neato, does not suit my needs. Is there a replacement carburetor available for the AX that will put the needle valve back where it belongs... on the carburetor? The remote needle valve does not work with the mounting setup I was planning on using, and I really don't want to change that around, as the firewall is already drilled.
Thanks in advance.
_____________________________
mjfrederick AMA 275874 NSRCA 4134
Maybe the Dingo ate your baby
       Post #: 1
RE: Question about O.S. 46 AX carb - 7/1/2008 4:53:36 PM
Bax
Status: offline
O.S. doesn't have a replacement carburetor for the .46AX that has the needle valve mounted to it.
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
(in reply to mjfrederick)
       Post #: 2
RE: Question about O.S. 46 AX carb - 7/1/2008 5:01:37 PM
mjfrederick
Status: offline
Since that's the case, how far from the carb can I mount the remote needle valve? Mounting it on the back of the engine is not an option at this point. I have tried every possible way to re-mount the needle to the backplate, and nothing will work. I don't want to have to return this engine, but I will if there is not a reasonable solution.
(in reply to Bax)
       Post #: 3
RE: Question about O.S. 46 AX carb - 7/2/2008 3:33:59 PM
Bax
Status: offline
You can mount the needle on the firewall or nearby. Too far away and you'll have a lot of lag when you adjust the needle, and you'll likely have fuel pressure problems. No more than a few inches is OK.
       Post #: 4
RE: Question about O.S. 46 AX carb - 7/2/2008 6:31:35 PM
mjfrederick
Status: offline
Great, thanks.
(in reply to Bax)
       Post #: 5
RE: Question about O.S. 46 AX carb - 8/29/2008 5:28:25 AM
Wblakeney
Status: offline
Any plans to offer an angled needle valve carb for the 46 AX like the rest of the AX seriers?
If it aint right, fix it. If you can't fix it, don't fly it.
(in reply to Bax)
       Post #: 6
RE: Question about O.S. 46 AX carb - 8/29/2008 3:49:52 PM
Bax
Status: offline
O.S. hasn't said anything. They don't talk until they announce a product or product change.
(in reply to Wblakeney)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.016RCU1
