my first rock crawler
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> my first rock crawler
Page: [1]
Login
my first rock crawler - 6/30/2008 7:38:16 PM
rustleracer23
Status: offline
i have been looking for a truck that can handle any terrain you throw at it. i have been looking at axial ax10. but there are three models.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTZW2**&P=0
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRXH6&P=0
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXVCZ3&P=0
i want to get the rock racer because it has crawling capabilities but still has some speed in it. but heres the problem. i don't like the body or color. can i put on the ax10 artr on the rock racer. also are accessory parts interchangeable between the three models??
< Message edited by rustleracer23 -- 6/30/2008 7:40:48 PM >
_____________________________
desert rat rustler(not ready yet) 4-tec
tamiya-midnight pumpkin,super hornet
       Post #: 1
RE: my first rock crawler - 6/30/2008 7:41:07 PM
Chris_RC
Status: offline
I heard the Axial crawler aren't that good. I am writing this with the Losi Rock Crawler ad in my face so just go on the Losi site and see how it crawls. It seems like a 1/10 crawler on the video.
For The Smoothes, Longest Lasting Diffs with the Best Customer Service- www.BFastRC.com
(in reply to rustleracer23)
       Post #: 2
RE: my first rock crawler - 6/30/2008 7:43:30 PM
rustleracer23
Status: offline
i looked at it i don't like it and i heard its 1/18
(in reply to Chris_RC)
       Post #: 3
RE: my first rock crawler - 6/30/2008 7:53:30 PM
Krawlin
Status: offline
quote:
ORIGINAL: Chris_RC
Not to be rude, but you obviously know nothing about crawlers. the Axial AX-10 crawlers are very good, top notch trucks, especially the kit version. They are meant for real competition, have great axle design, and can easily equal or outperform a TLT axled or Wheely King axled truck. What really ruins their image is all of the newbies in crawling who have totally stock trucks and know nothing about them and as soon as something breaks they say its crap. I am very into the crawling scene, I am a member of the Southern Arizona Radio Controlled Crawler Association, and most of the members of the club are running AX-10 axled trucks, and the ones running the AX-10's and AX-10 axled trucks are the ones who usually end up taking first place at the end of an event.
< Message edited by Jolly Roger Pirate -- 6/30/2008 7:58:28 PM >
~ Beater Truck Guru ~
       Post #: 4
RE: my first rock crawler - 6/30/2008 7:55:14 PM
rustleracer23
Status: offline
will scropion parts fit any of the ax10 models?
(in reply to Krawlin)
       Post #: 5
RE: my first rock crawler - 6/30/2008 8:06:54 PM
Chris_RC
Status: offline
I just heard that. A couple people said that the servo gears strip easy and a couple other things that i forgot.
       Post #: 6
RE: my first rock crawler - 6/30/2008 8:12:36 PM
Krawlin
Status: offline
quote:
ORIGINAL: Chris_RC
Well the kit version doesnt come with a servo, you add you own, but in rock crawling stripped servo is a very common problem, because most people dont run a servo saver for better wheel turning ability, which makes the servo more likely to strip.
       Post #: 7
RE: my first rock crawler - 7/1/2008 6:30:03 AM
rustleracer23
Status: offline
that is very true
       Post #: 8
RE: my first rock crawler - 7/1/2008 8:58:37 AM
magnat
Status: offline
Or they buy 2kg cheap Servo's instead of more beefier 10kg ones...
The Ax10 is one of the Best Value for money crawlers going.. If you get the rock racer, then just buy a 55T Lathe motor and go for it..
< Message edited by magnat -- 7/1/2008 8:59:32 AM >
Traction: What a drag.....
       Post #: 9
RE: my first rock crawler - 7/1/2008 12:02:22 PM
The Mad Modder
Status: offline
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUZ80&P=ML
This is a good one if you have FM radio or better(it's digital). It's a standard size servo, but it has metal gears, ball bearings, and enough torque to turn my TXT-1 tires at a standstill with no problem.
My RCs: Sledghammer 4x6, M03, Leo-X, Scania, Double Blaze, Mini-Baja, TXT-1.
(in reply to magnat)
       Post #: 10
RE: my first rock crawler - 7/1/2008 6:23:33 PM
sloppyG
Status: offline
the only thing that makes the RTR a "racer" is that it comes with a bigger pinion for higher speeds in addition to the one to be used for crawling
you can make the others a "racer" too by changing the pinion
(in reply to The Mad Modder)
       Post #: 11
RE: my first rock crawler - 7/1/2008 9:07:27 PM
IloveMYxt2
Status: offline
I like the Scorpion the best. I would love to have one and put some wheel spacers on it to give it a wider stance. I saw one at Hobbypeople once and it was a thing of beauty with the spacers on it.
XT2 (not stock)
(in reply to sloppyG)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
