Both Glow Plugs Dead on OS-160 Twin - Weird
Tower Hobbies
Logged in as Guest
  Printable Version
O.S. Engines O.S. BGX-1 3500 w/ BCM #4224 Pitt
Seller:  jmhernan
Details:   $200.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Both Glow Plugs Dead on OS-160 Twin - Weird
Page: [1]
Login
Both Glow Plugs Dead on OS-160 Twin - Weird - 6/30/2008 8:47:56 PM
Daniel-EL
Status: offline
I struggled this morning to get my DPM Super Cub's OS-160 Gemini started. No life whatsoever. I figured my on-board EDR-103 glow system was screwed up since I was getting fuel OK. Just before I gave up I removed a glow plug and put my Hot Shot on it....no glow. I took the other out and tried it with the Hot Shot treatment....still no glow. WTH?!! I got out a new OS F and tried it - it lit up like a spot light. I installed two new OS F plugs in the OS-160, and started it with one flip. Now how in the heck can you get two glow plugs to be totally dead at the same time? This one's a puzzle.
_____________________________
I don''t necessarily believe everything I say
...Marshall McLuhan...
       Post #: 1
RE: Both Glow Plugs Dead on OS-160 Twin - Weird - 6/30/2008 9:40:00 PM
skiman762
Status: offline
maybe the on board glow system dicided to fry them with too much juice
land of the FREE: you're free to get a JOB not a handout.
home of the BRAVE: they paid for it and you're enjoying it
(in reply to Daniel-EL)
       Post #: 2
RE: Both Glow Plugs Dead on OS-160 Twin - Weird - 6/30/2008 10:01:43 PM
w8ye
Status: offline
I agree about the EDR-103 fring the plugs
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
       Post #: 3
RE: Both Glow Plugs Dead on OS-160 Twin - Weird - 7/1/2008 12:00:33 AM
gkamysz
Status: offline
quote:
ORIGINAL: skiman762
Considering the circuit is a simple series circuit with two cells in series, it can't "decide to fry the plugs". The circuit is no different than a single plug and single cell. A more logical explanation for the failure is a lean run beating up both elements. There is only one carb on that engine so both cylinders would see similar conditions, and detonation is hard on plugs.
The only other logical explanation is that the glow battery was connected to a charger at high current while the glow driver was on. This could raise the voltage enough to blow the plugs. The recommend schematic allows for charging while the on board system is on.
< Message edited by gkamysz -- 7/1/2008 12:03:26 AM >
Greg
(in reply to skiman762)
       Post #: 4
RE: Both Glow Plugs Dead on OS-160 Twin - Weird - 7/1/2008 2:19:44 AM
w8ye
Status: offline
http://electrodynam.com/rc/EDR-103M/schematics.html
Original AMA #31261
(in reply to gkamysz)
       Post #: 5
RE: Both Glow Plugs Dead on OS-160 Twin - Weird - 7/1/2008 3:22:32 AM
gkamysz
Status: offline
quote:
ORIGINAL: w8ye
Yep, that's where I saw the schematics.
Greg
(in reply to w8ye)
       Post #: 6
RE: Both Glow Plugs Dead on OS-160 Twin - Weird - 7/1/2008 1:32:46 PM
Sport_Pilot
Status: offline
The plugs are not in series. Not possible with a single ground. BTW it is possible to blow several light bulbs in series. I have seen this, they blow at the same time if you put two 12 V DC bulbs in series with a 120 Volt AC power source. Poof!
Perhaps you meant that the battery is not enough to fry the plugs. That is true without the engine running, but the battery plus the heat of combustion my be enough. Still I suspect your conclusion was correct.
< Message edited by Sport_Pilot -- 7/1/2008 1:37:16 PM >
“I Saw Elvis at 1000 Feet” John Force
       Post #: 7
RE: Both Glow Plugs Dead on OS-160 Twin - Weird - 7/1/2008 2:05:50 PM
gkamysz
Status: offline
http://electrodynam.com/rc/EDR-103/schematics.html
Oops, this is what I actually looked at. The model number mentioned was the 103 not the 103M.
Greg
(in reply to Sport_Pilot)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.672RCU1
