Futaba 3114 servos for HBK2?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> Futaba 3114 servos for HBK2?
Page: [1]
Login
Futaba 3114 servos for HBK2? - 6/30/2008 11:41:50 PM
high flyer 777
Status: offline
I picked up some Futaba 3114 servos for my HBK2. Thought I read on one of the forums here
that they were replacements for the Esky stock servos.
Anway the 3114 are smaller & the top & bottom screw holes, both won't screw in to mount.
Just one of the screws will mount. Is there a servo adapter, or do I just plain have the wrong
size servo? If so, what ones do I need?
By the way. How are the Esky digital servos? Any good? Junk?
       Post #: 1
RE: Futaba 3114 servos for HBK2? - 7/1/2008 5:39:32 AM
kenhiraihnl
Status: offline
hi high...i get a lot of credit card offers in the mail...capital one or amex send clear plastic ones...i save them to use for scab repairs on frames, canopies, etc...ca, goop, or jb kwik and a little piece of credit card makes strong repairs/reinforcement...if the servo is not tall enough, maybe you can build it up and drill a hole where you need it...i use oem esky servos in my everyday hbk2...they're ok...btw, i'm using hitec hs-45 servos in my cf frame...fits perfectly...here's a pic...ken
Click to see fullsize image.
Click for fullsize
_____________________________
Raptor50V2│Raptor30V2│Logo10-3D(stretch)│Logo10(stretch) │Esky HBK2 2.4 │Gaui 200 2.4 │Walkera 4#3 2.4
(in reply to high flyer 777)
       Post #: 2
RE: Futaba 3114 servos for HBK2? - 7/1/2008 6:59:33 AM
high flyer 777
Status: offline
Thanks Ken. I like the idea of the HS-45's. Got the 3114's at my LHS.
He will trade the 3114's for me I'm sure. Good pics! Thanks!
(in reply to kenhiraihnl)
       Post #: 3
RE: Futaba 3114 servos for HBK2? - 7/1/2008 7:31:46 AM
kenhiraihnl
Status: offline
hi high...you might refer to this link to make sure that whatever servos you want will fit...btw, hitec servos turn clockwise, and futaba turns counter-clock...ken
http://www.servocity.com/
       Post #: 4
RE: Futaba 3114 servos for HBK2? - 7/1/2008 1:29:32 PM
NoX_sp
Status: offline
If you are going to use the xtreme frame, you can use almost any servo, I have mounted the S3114 without any trouble.
       Post #: 5
RE: Futaba 3114 servos for HBK2? - 7/1/2008 2:09:25 PM
dicharry
Status: offline
I've heard alot of good things about the Tower Pro SG90, and that they are a drop in fit. DEAL EXTREME has these servos for $6.00 each shipped.
Don
http://www.dealextreme.com/details.dx/sku.12859
(in reply to NoX_sp)
       Post #: 6
RE: Futaba 3114 servos for HBK2? - 7/1/2008 3:30:48 PM
high flyer 777
Status: offline
I've purchased 7.4v 900mah batteries from dealextreme several times.
So how do the Tower Pro servos stack up, say against the HS-55. I'm
thinking of doing the HS-45's.
(in reply to dicharry)
       Post #: 7
RE: Futaba 3114 servos for HBK2? - 7/1/2008 3:32:28 PM
high flyer 777
Status: offline
Ken I can't tell from your pic w/the HS-45's. Did you get rid of the Z-bend
links on the servos?
       Post #: 8
RE: Futaba 3114 servos for HBK2? - 7/1/2008 7:09:18 PM
kenhiraihnl
Status: offline
hi high...i'm right at that point in my build...i already have b400 short screw-in balls and links...btw, i noticed that jag carries an upgrade hbk2 linkage set that eliminates the z-bends...btw, i've been wanting to eliminate the 'hoop link' between the control arms on the washout and the paddle control arm...it's a pita to remove the hoop link (gotta remove the blade grip)...the esky cnc paddle control arm is removable!!! it might be possible to use a straight link instead of the hoop link!!! we'll see...ken
       Post #: 9
RE: Futaba 3114 servos for HBK2? - 7/2/2008 3:57:12 PM
high flyer 777
Status: offline
Ken, thanks for pointing out the linkage sets. I traded my 3114's in for the HS-45's.
The HS-45's do drop right in & they have karbonite gears. All for a $2 cost difference
per servo.
       Post #: 10
RE: Futaba 3114 servos for HBK2? - 7/2/2008 7:31:59 PM
Zimatosa
Status: offline
quote:
ORIGINAL: kenhiraihnl
Mr. Ken,
I will buy a set from you when you figure that out. Ever since I saw the Guai linkage you posted months ago, I have tried to "make" my own with little to no success....I keep over-bending metal and breaking the plastic inner threads...
Keep us in the loop! Hehe
Z
Without deviation from the norm, progress is not possible.
       Post #: 11
RE: Futaba 3114 servos for HBK2? - 7/3/2008 6:13:33 AM
funflier
Status: offline
The HS-65 is a drop in for the stock esky servos and its pretty easy to put ball links on it. Its fast, very strong, with Karbonite gears. As its for the cyclic It is ok as far as direction of rotation but if your running your stock radio you can and cant do it. Your stock radio has a provision for changing the servo directiion however it has no provision for changing the Swash mix settings which have to be moved down to about 20% when you go to the ball links. I guess you could make up some new Z bend links and get around that.
I spent a lot of time centering and adjusting my HS-65 with my subtrim to get them to move in perfect unison throughout their neccessary range which is not very much actually.
Trading the 3114 for the HS-45? is that a step in the right direction as the HS-45 is only about a 13 oz servo at 5 volt and relativly slower at .14 sec as the 3114 is a .10 sec servo with over 18 oz of torque. With those figures your faster stronger servo is a stock Esky compared to the HS-45. You could have went to the HS-65 for about 20$ each on Ebay.
King ll, 3900 w/10t pin, cnc head, custom cnc/trex tail, 43t + upgrade, Telebee gyro, Dx6i TX w/6100e RX, HS-65 servos. etc.
       Post #: 12
RE: Futaba 3114 servos for HBK2? - 7/3/2008 6:23:34 PM
funflier
Status: offline
Are you still trying to make those little "hoop" links?
Why not give that up and just use ones like I made?
Ignore the blade holder and just hook up a stright rod.
I think I should refine them a little more though so they dont look so "prototype"
(in reply to Zimatosa)
       Post #: 13
RE: Futaba 3114 servos for HBK2? - 7/3/2008 6:41:05 PM
Zimatosa
Status: offline
quote:
ORIGINAL: funflier
Did you have those on your Helicopter when i saw it? If so, I do not remember them . I really like the look of the Gaui linkage. i am shooting for something with a nice streamline-type look to it to hug the blade grips and of course, work well. Where are the pics. of your "prototypes"?
(in reply to funflier)
       Post #: 14
RE: Futaba 3114 servos for HBK2? - 7/3/2008 8:41:48 PM
funflier
Status: offline
I dont remember if they were on or not, I dont think I had them installed as you were asking about bending that spring steel rod and I remember saying something about if you went that route you would probably need to heat treat the linkage after you softened it to bend it. I "lost" them when I put back on the plastic washout (nowhere to put the ball joints). Never saw a Gaui linkage up close.
If I get time tonight I will put back on a cnc washout and take a picture so you can see how they were set up.
       Post #: 15
RE: Futaba 3114 servos for HBK2? - 7/4/2008 9:21:09 AM
