Can someone explain thermals???
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Gliders, Sailplanes and Slope Soaring >> Can someone explain thermals???
Page: [1] 2   next >   >>
Login
Can someone explain thermals??? - 7/1/2008 1:21:33 AM
sgtcat
Status: online
Hey guys i'm looking for a plane and gliders/slope divers REALLY spark my interest.I see a ton of people talking about thermals and staying in the air.What exactly is a thermal?I'm kind of new to plane flying and don't know any terms or any of this stuff.:?
_____________________________
XL-5 Rustler
RS4 3 with os cv max .12
       Post #: 1
RE: Can someone explain thermals??? - 7/1/2008 1:35:43 AM
Tall Paul
Status: offline
The basics...
http://en.wikipedia.org/wiki/Thermal
< Message edited by Tall Paul -- 7/1/2008 1:36:14 AM >
Sparky Paul
http://www.angelfire.com/indie/aerostuff
(in reply to sgtcat)
       Post #: 2
RE: Can someone explain thermals??? - 7/1/2008 2:00:04 AM
Alex.schweig
Status: offline
You might want to think of a thermal as a rising, spiraling mass of warm air... Thermals are bubbles of air that are heated by refraction, heat radiating off the ground. A thermal starts as a mass of cold air which then gets heated and breaks off, forming a bubble of warm rising air, because hot air tends to rise. You can take advantage of the rising air to stay aloft with a glider. So, to catch a thermal, you need to be able to "see" the invisible masses of hot air. You will learn to do this by observing what kind of land radiates more heat, for example a parking lot or highway will radiate far more heat than a lake or dense woods. To catch thermals you need a stable glider with a very efficient airfoil...
You launch the glider, usually by means of a motor or high start. A high start is a long piece of Bungee cord that acts as a slingshot with your glider as the load.
You circle around and if there are any thermals at all, you will see that sometimes one wing tip will rise and cause the plane to bank. What you have to do is turn hard towards the area where your wing tip rose: if the left wing tip rises you bank hard left. By circling around, you will soon find a spot where the plane rises more and more as you spiral. You should keep spiraling in that spot, smoothly, and the warm air will carry your plane upwards. You can then disengage the thermal and look for another one.
The best kind of glider to start with will be a glider with a large wing. the bigger the wing is, the better. The wing should have some Dihedral, which means it curves upwards at the tips. It will usually be a 2 or three channel plane, which means that you have only elevator and rudder control, or elevator, rudder and flaps/brakes. The rudder is like the rudder in a boat: it steers the plane. The elevator controls the elevation and descent, and the flaps are surfaces at the back of the wing that extend or lower themselves to provide more wing area and wing efficiently. Brakes are surfaces that partially destroy the wing's efficiency, lowering speed for easy landings.
You should buy a four to six channel radio to begin with. Your radio will come with servomotors, small devices that move the surfaces, a battery and a receiver, as well as some accesories. Futaba and Spektrum are very reliable brands of Radios, so you should want to go for the best you can afford.
Here I will give you a few links to good starter planes and radios:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEFJ4**&P=ML : The T4YF, the best starter radio. $119.99
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSFY3&P=ML : The 6EX, a more advanced and flexible radio which uses 2.4 gigahertz technology to eliminate interference, available for $ 259.99
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJ597&P=0 : The spectra, a great glider with a motor for easy thermal catching, kit form
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFG09&P=0 : SIG riser, easiest plane to fly, very cheap, available in kit form
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXELP0&P=0 : The Gentle Lady, I laerned to fly with one of these, available in ARF (Almost Ready To Fly)
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJYP9&P=0 : The Spirit 100, Great plane, available as an ARF
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLGM6&P=0 : The Fling 2M, very light and very efficient airfoil, great for thermals, available as an ARF and also available in a 50 inch version.
http://www3.towerhobbies.com/cgi-bin/wti0161p?&I=LZ1491** : Finally, the Spectra electric assisted glider, available as an Ultimate Combo for 225 dollars. Includes everything you need, even rubber bands and alkaline batteries for the radio...
Well I hope that helps. Now I need to rest my poor fingers, Ive been typing too long...
(Previously Zagiz) Lima, Peru... Great wind, great slopes! Proudly flying my brand new Ferox slope racer!
Parque Gandhi
       Post #: 3
RE: Can someone explain thermals??? - 7/1/2008 2:10:24 AM
sgtcat
Status: online
yeah i know the plane terms like contrls.what about something like these?
http://www.wonderhobby.com/skyha3rareco.html
http://www.raidentech.com/rercracoplgl.html
http://www.raidentech.com/3rarecoaiwis1.html
XL-5 Rustler
(in reply to Alex.schweig)
       Post #: 4
RE: Can someone explain thermals??? - 7/1/2008 2:20:34 AM
Alex.schweig
Status: offline
Wait a second... Are you thinking thermals or slope soaring? Cause slope soaring is very different.
Parque Gandhi
       Post #: 5
RE: Can someone explain thermals??? - 7/1/2008 2:23:36 AM
soarrich
Status: offline
Get this:
http://radiocarbonart.com/Pages/asecthermalmain.html
After watching this you'll know more about thermals than 90% of sailplane pilots, it's the best info you can get.
Rich Border
       Post #: 6
RE: Can someone explain thermals??? - 7/1/2008 3:01:31 AM
sgtcat
Status: online
um....slope soaring is off hills and stuff right?or am i tottaly confused?and can't i just used a slope diver for gliding?
XL-5 Rustler
(in reply to soarrich)
       Post #: 7
RE: Can someone explain thermals??? - 7/1/2008 3:29:07 AM
Sailplane
Status: offline
Soarrich,
Very simply, a thermal is some-what like a dust-devil. In a dust-devil, air heated by the earth's surface rises. Warm air is lighter than cooler air and therefore rises. You can see the dust-devil because of rising and rotating silt, sand, paper, and other trash. Once in Hawaii, while on training manuvers with the army on the "Big Island", a very large and strong dusd-devil made its way through our compound. Its vertical force carried silt, sand, rocks, doors, windows, and other heavy objects hundreds of feet upward; it was much like a tornado in that it had rotating winds, but had no weather associated with it. Our models or full scale sailplanes use the rising warm air to "lift" them upward. The rising warm air cools at altitude and falls downward as "sink". As a pilot, to gain altitude, you must learn to seek out the "lift" and stay out of the "sink".
Welcome to our sport,
Ernie
       Post #: 8
RE: Can someone explain thermals??? - 7/1/2008 3:41:31 AM
Alex.schweig
Status: offline
In slope soaring the pilot needs a slope. Wind pushes against the slope and forms a vertical wind current off the lip of the slope. You use this current to stay aloft. The current will come at an angle and it is at that angle at which you will get the best lift. For slope soaring you need a slope or tall hill and winds of at least 6 mph. Slope soarers are often heavier than thermal birds and usually have ailerons. Thy are much faster and can do many more maneuvers than thermal models. You can hand launch off a slope or use a winch. Read my post Slopes in Peru (In Response to Evan-RCU) and you can see some slopes and sloper models.
Parque Gandhi
(in reply to Sailplane)
       Post #: 9
RE: Can someone explain thermals??? - 7/1/2008 3:41:35 AM
soarrich
Status: offline
Soarrich has been a Level IV for 20 years.
Rich Border
       Post #: 10
RE: Can someone explain thermals??? - 7/1/2008 3:43:47 AM
sgtcat
Status: online
thanks evryone.i don't have a plane though.I'm selling an rs4 and have like 4 or 5 people making offers so in about a week i'll buy onne.Can i get one for like $100,$130 maybe as a RTF?Or do i have to spend about $200?
XL-5 Rustler
       Post #: 11
RE: Can someone explain thermals??? - 7/1/2008 3:45:29 AM
Alex.schweig
Status: offline
RTFs are good but have the disadvantage that hey never come with especially good radios. Try looking in the Sailplanes-Almost Ready To Fly section in Towerhobbies.
Parque Gandhi
       Post #: 12
RE: Can someone explain thermals??? - 7/1/2008 3:49:05 AM
sgtcat
Status: online
ok.can i get a setup for around a $150?
XL-5 Rustler
       Post #: 13
RE: Can someone explain thermals??? - 7/1/2008 3:58:18 AM
Alex.schweig
Status: offline
Depends if you get a balsa built up plane or foam moulded.
Parque Gandhi
       Post #: 14
