Engine Help!!! TT39H
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Thunder Tiger - Raptor 30, 50, 60, 90 >> Engine Help!!! TT39H
Page: [1]
Login
Engine Help!!! TT39H - 7/1/2008 3:17:26 AM
mapleleafs
Status: offline
Hey guys!
I recently bought a new TT39H and put it in my Raptor 30v2. I broke it in on 15% CP for 2-3 tanks with no issues.(Then the problems came)
-Firstly, i noticed that the engine was hot after only 3-4 minutes of hovering(could not touch backplate for more than 1-2 seconds...ouch).
-Secondly, when going from (idle-up 1) back down to (normal flight), the heli goes wack and starts to shack/engine burps and loose control. However, it dis-appears after 5-6 seconds.
-Thirdly(the scariest part), after landing and lowering throttle to idle, the same thing hapens. The engine begins to burp and gargle, along with the heli violently shaking.
Before posting this i have done the following:
-new glow-plug(failed)
-tryed to richen and lean(failed)
-cleaned tank(failed)
-replaced all fuel lines(failed)
-tightened engine bolts(couple a bit loose)
-checked for loose screws(none)
After doing all this, there was no success.
I called Arden at A & J Hobbies but he was not sure either.
I'm open to all suggestions????????
ps. Note that even when both needles are set 4 turns open the engine still seems to be running very warm.
       Post #: 1
RE: Engine Help!!! TT39H - 7/1/2008 5:29:37 AM
FlyingHigh 400
Status: offline
Take it back and exchange it..
_____________________________
Raptor 30,GY401/JR NES810G,OS.37/Revolution tune Pipe. http://www.youtube.com/user/flyinhigh450
(in reply to mapleleafs)
       Post #: 2
RE: Engine Help!!! TT39H - 7/2/2008 6:14:14 AM
JoDyO
Status: offline
.. with a O.S 37 SZH and all you problems will disappear. True
(in reply to FlyingHigh 400)
       Post #: 3
RE: Engine Help!!! TT39H - 7/2/2008 12:39:47 PM
gj1803
Status: offline
The TT39's are abit sensitive when setting up the slow and high speed needles. If you dont get the balance right, they are awful. My only suggestion is persevere with the settings, make sure the carb is operating ok and its not sucking air thru the seal. Once set up correctly, they are a good, although a little under powered for aggressive flying, reliable engine.
GJ
(in reply to JoDyO)
       Post #: 4
RE: Engine Help!!! TT39H - 7/2/2008 9:30:45 PM
FlyingHigh 400
Status: offline
quote:
ORIGINAL: JoDyO
Mine is going in tonight .
Click to see fullsize image.
Click for fullsize
(in reply to JoDyO)
       Post #: 5
RE: Engine Help!!! TT39H - 7/2/2008 10:00:42 PM
gj1803
Status: offline
Hi FH400,
Let me know how she goes after it is run in. I want to know how much it bogs between full pos pitch and full neg pitch on stationary flips etc
GJ
       Post #: 6
RE: Engine Help!!! TT39H - 7/2/2008 10:19:01 PM
FlyingHigh 400
Status: offline
quote:
ORIGINAL: gj1803
Hi FH400,
GJ
I will report back with a video this weekend but heres what its like with a OS.32 http://www.rcuniverse.com/forum/m_7684733/tm.htm .I'll post the video in that thread .
(in reply to gj1803)
       Post #: 7
RE: Engine Help!!! TT39H - 7/3/2008 1:01:35 PM
gj1803
Status: offline
Thanks FH
GJ
       Post #: 8
RE: Engine Help!!! TT39H - 7/3/2008 2:21:55 PM
BarracudaHockey
Status: offline
Why would you go from full positive to full negative in a flip?
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
       Post #: 9
RE: Engine Help!!! TT39H - 7/3/2008 9:48:21 PM
mapleleafs
Status: offline
FINGER HAPPY??
(in reply to BarracudaHockey)
       Post #: 10
RE: Engine Help!!! TT39H - 7/3/2008 11:08:37 PM
gj1803
Status: offline
lol when I say flip, its more of a flop. I get v nervous about throwing the damn thing about. As soon as its the wrong way up I find i am stick happy pulling back and putting loadsa neg pitch on, then rollin her over again and makin sure she stays there by puttin loadsa pos pitch on. Its been only 3 flights in idle up 1 so a little slack is reqd please. Once I get some confidence I am sure it wont be so bad.
GJ
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
