SilverFoxCPF
Joined: 1/5/2008 From: Bellingham, WA, USA Status: offline
Hello Nikq, The purpose of the "forming" charge is to evenly distribute the electrolyte and charge throughout the cell electrodes and separator. My opinion is that the best results come from starting with a discharged cell and using the 0.1C charge rate for the full 16 hours. On the other hand, if you are trying to balance a pack, you can set the charge limit a little low, charge at 1C, then finish off the charge and balancing at 0.1C for a few hours. For example if you had a 4600 mAh pack and you are starting from a discharged condition, you could set your maximum charge limit to 3500 mAh, charge at 4.5 amps until you have put back the 3500 mAh into the pack, then drop to a 460 mA charge rate for a few hours to finish the charge and to bring the cells in the pack into balance. This works great for balancing, but I don't think it is the best way to go for "forming." Tom
