What Engine would you use?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> What Engine would you use?
Page: [1]
[Poll]
O.S. FS-70 II Surpass
  5% (4)
Saito 72 AAC
  8% (6)
YS 63-S
  85% (61)
Total Votes : 71
(last vote on : 7/16/2008 1:53:06 PM)
(Poll will run till: -- )
Login
What Engine would you use? - 7/1/2008 11:12:22 PM
Flyer 202
Status: offline
I would like to find out which engine is more popular for a Great Planes Tracer.
Thanks, Flyer 202
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: What Engine would you use? - 7/2/2008 9:31:54 AM
dnugent
Status: offline
I would go with the reliability of O.S...................
(in reply to Flyer 202)
       Post #: 2
RE: What Engine would you use? - 7/2/2008 5:03:24 PM
4u2nv-RCU
Status: offline
The reliabilty of the OS is undeniable but the YS , once set up correctly, is also fairly bulletproof and has gobs of power with a little less weight. I am not a YS guy as I have run the big OS 2 strokes the past 4 years in my larger planes. The one YS engine I have LOVED has been the 63 I have in my Oxalys50. Sweet combo!!!!!
_____________________________
power corrupts...
absolute power corrupts absolutely
(in reply to dnugent)
       Post #: 3
RE: What Engine would you use? - 7/2/2008 6:30:39 PM
martinoto
Status: offline
I got the OS. It is strong, reliable and it has more power that it seems, I truly believe it is a lot more than a two.stroke 45.
But its HEAVY. You will probably have to move everything way back to get the proper CG. It is no longer in production, and the replacements are lot more expensive (56a = $299; 81a = $340).
So, I vote for the YS. It is lighter, cheaper and has more power.
Regards,
"Give me balsa and a cutter, and I will cut a little too much"
       Post #: 4
RE: What Engine would you use? - 7/2/2008 10:33:05 PM
Timbba
Status: offline
YS is best of these engines for aerobatics and 3D because of its highpressurised and regulated fuelsystem that allows you to locate fueltank near CG, no trim change during flight!
And YS has such throttle response those others cannot compete with
-FIN 4853-
-Timo Huhtamäki-
       Post #: 5
RE: What Engine would you use? - 7/2/2008 11:00:29 PM
Flyer 202
Status: offline
The YS looks like it is the most popular engine in this selection and it was the engine I was interested in before the thread started.
But now it is becoming clear that it is the lightest most powerful engine for the money.
Flyer 202
(in reply to Timbba)
       Post #: 6
RE: What Engine would you use? - 7/3/2008 6:40:25 PM
randy109
Status: offline
I had tracers with the Saito 72 and a 46 two stoke. Both had plenty of power. I find the Saito a lot easier to run and adjust than the YS.
       Post #: 7
RE: What Engine would you use? - 7/4/2008 5:28:03 AM
majortom-RCU
Status: offline
Saito and OS are great sport engines. I own them, fly them with pleasure. The YS are competition engines, do everything the sport engines do, but with better power/weight. If you are thinking of getting into competition aerobatics, you really should check out the YS line.
(in reply to randy109)
       Post #: 8
RE: What Engine would you use? - 7/4/2008 9:42:27 AM
dnugent
Status: offline
I run an OS 160 2stroke in a 2x2 patternship no problems; VERY reliable but also HEAVY. I DO run my tank on the C of G - no problems.
(in reply to majortom-RCU)
       Post #: 9
RE: What Engine would you use? - 7/4/2008 9:16:27 PM
wagen017
Status: offline
I flew the Tracer with a Saito-72, and think it is the perfect engine for this plane. If you want a bit more power, go for the Saito-82! But IMHO, you don't need it for this plane.
Just make sure you have friends around who know how to adjust a YS if you get one. I have seem some very frustrated people looking at YS engines while I was flying my lines....!
Club Saito member #371
       Post #: 10
RE: What Engine would you use? - 7/5/2008 12:30:31 AM
Zippi
Status: offline
quote:
ORIGINAL: Flyer 202
Thanks, Flyer 202
I don't know about the Tracer but if I was going to pick one it would be one you didn't mention. I'd get the Saito .82. The YS is a good engine but to get all the power you need to run some high nitro fuel and the Saito .82 will give you what you want on 10% fuel.
"It Ain''''t Lookin Good"
http://zippi.50webs.com/index.htm
       Post #: 11
RE: What Engine would you use? - 7/5/2008 5:58:17 PM
jeffk464
Status: offline
I would strongly advise you use the 55AX, its absolutely reliable and a real torquer.
(in reply to Zippi)
       Post #: 12
RE: What Engine would you use? - 7/5/2008 6:32:18 PM
rainedave
Status: offline
I'm with jeffk464. If you're not completely set on a 4-stroke then the AX .55 is a great choice. I have one in my Venus 40 and it is a great match (5lbs., 8.5ozs. less fuel). You can buy some nice servos or lots of fuel with the money saved. I'm running mine on Powermaster 5% and it runs great. So, you won't be needing to spend all that money on high nitro YS fuel. I mounted mine at about 10 o'clock to avoid dealing with inverted issues (which I seem to always have). It's not as streamlined, but it's simple to fuel, start and adjust.
David
Click for fullsize
(in reply to jeffk464)
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
