lil help with tmaxx2.5r
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> lil help with tmaxx2.5r
Page: [1]
Login
lil help with tmaxx2.5r - 7/2/2008 4:10:11 AM
redthugneck
Status: offline
First I have a tmaxx 2.5
First question - the carb fell off today. I dont think its broke but i was wondering if it has a screw that holds it in place or is it just a puch fit?
Second - What is a good setting to a good tuned truck or atleast a good base line to start with im not sure if their are different settings for different types of trucks
Third - my reverse isnt working if i switch it into reverse i get a grind like the gears are stripped but then it doesnt want to switch back into forward unless i stand it on it nose and tap it . It started doing it when i let a friend runn it < i know big mistake letting a novice runn it> and he got it stuck and switched it into reverse and hit full throttle
Apperciate any help
_____________________________
ITS A HIMOTO THANG YOU WOULDNT UNDERSTAND
HIMOTO RACING LET THE REVOLUTION MOVE YOU
       Post #: 1
RE: lil help with tmaxx2.5r - 7/2/2008 4:50:59 AM
cmerritt
Status: offline
there is a screw holding the carb on
stock carb setting are:
HSN=4 turns out
LSN= flush
"It''s funny ''till someone gets hurt... then it''s HILARIOUS!"
(in reply to redthugneck)
       Post #: 2
RE: lil help with tmaxx2.5r - 7/2/2008 4:55:34 AM
superman11
Status: offline
There is a bolt that hold the carb in place, this is the only picture of a 2.5 engine facing the right way... the bolt is circled in red
For tuning it depends on your weather, you can reset your needles back to factory and retune, HSN 4 turns from closed, LSN flush with the inner ring, Idle screw, if you take off the air filter and get a small zip tie adjust the idle screw until the zip tie can barely fir in the opening, no throttle...
For the tranny it sounds like you might have to take it out and see if the gears are stripped, when you shift is the servo moving the little pin going into the tranny?
Click to see fullsize image.
Click for fullsize
< Message edited by superman11 -- 7/2/2008 4:57:07 AM >
T-Maxx 2.5 With Pull Start and Nova Cooling Head, RPM Arms, Big Bore Shocks, VG Roll Cage, and a Motor Saver Filter
       Post #: 3
RE: lil help with tmaxx2.5r - 7/2/2008 6:13:32 AM
systemlord
Status: offline
Yes cmerritt is right, make sure the low speed needle is flush with the steel ring around the needle, my brother's wouldn't run at 4 turns but mine was way rich at anything more than 3 3/4 turn on the high speed needle.
UE SuperMaxx 1/8th Monster Truck* Custom Duratrax Vendetta Mamba 25 Motor 5400kv Impulse 3S1P 11.1v 950mAH 25C * Raptor 60
(in reply to cmerritt)
       Post #: 4
RE: lil help with tmaxx2.5r - 7/3/2008 3:26:58 AM
redthugneck
Status: offline
thanks for the help with the carb
yes the servo does move as far as a lil pin im not sure
(in reply to systemlord)
       Post #: 5
RE: lil help with tmaxx2.5r - 7/3/2008 3:47:30 AM
superman11
Status: offline
I think you might need to take the tranny out and see if anything is stripped.... Good luck!
       Post #: 6
RE: lil help with tmaxx2.5r - 7/3/2008 3:58:31 PM
Xtfreak
Status: offline
SUPERMAN11 WHy is your engine gold?
BMX, Its not a passion...its a way of life - Peter Langman.
       Post #: 7
RE: lil help with tmaxx2.5r - 7/3/2008 4:35:09 PM
superman11
Status: offline
That is not my engine, that is the only picture that I could find online of a 2.5 facing the right direction! LOL
(in reply to Xtfreak)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.109RCU1
