What would happen if I put %30 nitro fuel in a car that recommends %20?
Tower Hobbies
Logged in as Guest
  Printable Version
Associated MGT 8.0 - RTR
Seller:  ScottInMichigan
Details:   $450.00   |  10/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car General Discussions >> What would happen if I put %30 nitro fuel in a car that recommends %20?
Page: [1]
Login
What would happen if I put %30 nitro fuel in a car that... - 7/3/2008 4:30:31 AM
mystikdragon7
Status: offline
Just like the title says. I bought a Tornado BB with the Vertex 18 motor. On the directions it recommends %15- %20 nitro fuel. So what would happen if I put in %30 nitro fuel or higher nitro fuel?
       Post #: 1
RE: What would happen if I put %30 nitro fuel in a car... - 7/3/2008 4:31:54 AM
R/C fan-addict
Status: offline
KABOOM!!!!
_____________________________
Savage 25 RTR|Emaxx w/ dual s-600 setup|TA-05|TLT (x2) |Baja King|TRF415 w/ GTB 4.5|Tamiya Pajero|Jammin CRT.5 BL
(in reply to mystikdragon7)
       Post #: 2
RE: What would happen if I put %30 nitro fuel in a car... - 7/3/2008 7:30:46 AM
GYNAIKAS
Status: offline
Nothing. If you run 3-4 tanks of it then something may go wrong indeed. I run 25% in my 18ss engine and everything is fine.
I simply love perfection...do something as good as you can or don't do it at all...
(in reply to R/C fan-addict)
       Post #: 3
RE: What would happen if I put %30 nitro fuel in a car... - 7/3/2008 8:45:04 AM
sheograth
Status: offline
You're just risking premature engine death.
www.mangosnake.com
(in reply to GYNAIKAS)
       Post #: 4
RE: What would happen if I put %30 nitro fuel in a car... - 7/3/2008 8:57:50 AM
qaiz
Status: offline
Used 30% on a Jammin .12 engine, nothing happened.? The Instruction Manual said " Only use fuels upto 20% "....
I used 30% from the start, didnt switch...Stiill runs like new 2 gallons later...
Emirates Hobbies
Support your LHS.!
(in reply to sheograth)
       Post #: 5
RE: What would happen if I put %30 nitro fuel in a car... - 7/3/2008 4:21:53 PM
RCtruckRacer
Status: online
The only thing that happens is that the timing is advanced. If you go up in Nitro by that much though, you should be adding a head shim. Sometimes that is not enough to compensate, so then also going to a colder plug usually corrects the timing enough if just adding a shim didn't.
What you can experience by advancing the timing too far is detonation. That is where the fuel inside the chamber burns much too soon - well before the piston hits TDC (Top Dead Center). This will cause all kinds of stress on the conrod and other internals.
Some people see the glass half full. Others see it half empty. I see a glass that's twice as big as it needs to be.
My opinions are my own, and are not necessarily those of RCU
(in reply to qaiz)
       Post #: 6
RE: What would happen if I put %30 nitro fuel in a car... - 7/3/2008 4:54:48 PM
GYNAIKAS
Status: offline
What RCtruckRacer is right and also instead of adding a shim you can get a colder glow plug. It should do the job cause .18 engines can handle more nitro percentange than .12 and .15 ones.
(in reply to RCtruckRacer)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU1
