Immediate Nose Dive when Jumping
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> Immediate Nose Dive when Jumping
Page: [1]
Login
Immediate Nose Dive when Jumping - 7/3/2008 7:08:03 PM
cat_on_a_cob
Status: offline
Yah whenever I take my rusty off a job (25 degree angle) it just goes into an immediate nose dive? Sometimes even when Im in the gas while airborne
       Post #: 1
RE: Immediate Nose Dive when Jumping - 7/3/2008 7:10:05 PM
Nesal
Status: offline
Brake while in the air, that should bring the nose up!
(in reply to cat_on_a_cob)
       Post #: 2
RE: Immediate Nose Dive when Jumping - 7/3/2008 7:28:14 PM
cat_on_a_cob
Status: offline
I thought hitting the brakes caused the nose to go down and gas would bring it up?
(in reply to Nesal)
       Post #: 3
RE: Immediate Nose Dive when Jumping - 7/3/2008 7:43:36 PM
Nesal
Status: offline
Im prerry sure its the other way round!
       Post #: 4
RE: Immediate Nose Dive when Jumping - 7/3/2008 8:04:59 PM
cat_on_a_cob
Status: offline
IDK I've watched a few how to videos in the past and thats what they said...
(in reply to Nesal)
       Post #: 5
RE: Immediate Nose Dive when Jumping - 7/3/2008 8:12:07 PM
Chris_RC
Status: online
more throttle in the air=nose goes up
brake in the air=nose goes down.
IDK where you heard that.
_____________________________
Losi XXX-T MF2~ XXX-NT Sport RTR 2~ Losi Mini-Baja (F/S, PM Me. dirt cheap)~ Losi XXX Buggy (SOLD)
       Post #: 6
RE: Immediate Nose Dive when Jumping - 7/3/2008 8:20:39 PM
cat_on_a_cob
Status: offline
I was right
maybe I am just not going fast enough? and the nose just drops once It gets off the top of the ramp?
(in reply to Chris_RC)
       Post #: 7
RE: Immediate Nose Dive when Jumping - 7/3/2008 9:18:23 PM
motorhead91
Status: offline
just blip the throttle while its in the air, or keep on the gas after it has launched and see what happens
Chuck Norris Doesn't Have To Write Books. The Words Assemble Themselves In Fear.
       Post #: 8
RE: Immediate Nose Dive when Jumping - 7/4/2008 1:13:02 AM
josh h
Status: offline
My buddy's rustler does the same thing. I guess the rusty's are nose heavy. My xxx-nt is a lot better but likes to drop the front down some to. What I do is hit the ramp at a steady pace and then just before the front wheels leave the ramp, hit the throttle some. Just blip the throttle before it leaves. You may need to tap the brakes some in the air to drop the front but it should fly better. And you hit the throttle to raise the front and brake to drop the fron end down.
XXX-NT With a trx 2.5 / Factory Team RC10GT With O.S. max .12 / GS SUT with RB .21 / Stock GS SUT
(in reply to motorhead91)
       Post #: 9
RE: Immediate Nose Dive when Jumping - 7/4/2008 2:09:41 AM
ThunderbirdJunkie
Status: offline
stiffen up the rear suspension adn that should get rid of your problem.
"Some people can mess up an anvil with a rubber hammer"-46u
(in reply to josh h)
       Post #: 10
RE: Immediate Nose Dive when Jumping - 7/7/2008 3:52:55 AM
crispyspa
Status: offline
Hit the ramp with some throttle left, then just as you are about to leave the ramp, go full throttle...works for me.
"Are you alright, son? I keep hearing the most terrifying sounds in there." (Foghorn Leghorn)
(in reply to ThunderbirdJunkie)
       Post #: 11
RE: Immediate Nose Dive when Jumping - 7/7/2008 4:26:19 PM
FastestJato
Status: offline
Dude just go ike 15 or 20 mph and everything will be fine, if noy go faster...
Brakes = Nose Down
More Throttle = Nose Up
So here you go....
GO JATO OR GET LEFT BEHIND
(in reply to crispyspa)
       Post #: 12
RE: Immediate Nose Dive when Jumping - 7/8/2008 1:35:00 PM
raymanh
Status: offline
quote:
ORIGINAL: FastestJato
Brakes = Nose Down
So here you go....
second that!
(in reply to FastestJato)
       Post #: 13
RE: Immediate Nose Dive when Jumping - 7/8/2008 2:26:50 PM
Logi3
Status: offline
Double check your rear brakes are not binding or anything, i had this on my ST-1 and i was struggeling to keep the nose up even when throttling. Once i sorted this i could control the flight perfect.
Another thing to check is when your hitting the ramp, make sure your not bouncing as you hit the jump, i noticed this on a certain jump. I was hitting it, car was bouncing (only slighty) and the rear was just clipping the end of the jump as the car took off, pushing the nose down.
HN XR-C1 FTSE / Mugen MBX5T Prospec / TTR ST-1
Go .21 7 Port / Go .21 5 Port / Go .25 6 Port
(in reply to raymanh)
       Post #: 14
RE: Immediate Nose Dive when Jumping - 7/8/2008 3:21:26 PM
tcv_racing
Status: offline
quote:
ORIGINAL: ThunderbirdJunkie
Im pretty sure its the other way around..
front spring should always be stiffer than the rear to prevent nose dives during jumps..
HPI Firestorm 10T
Tamiya TT01 Rally
       Post #: 15
RE: Immediate Nose Dive when Jumping - 7/8/2008 4:00:48 PM
dcfrickle32
