Blade 400 gyro setup???
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> Blade 400 gyro setup???
Page: [1]
Login
Blade 400 gyro setup??? - 7/3/2008 8:54:44 PM
flycfii
Status: offline
Hey all, can anyone here explain how to setup the tail servo and gyro on a blade 400? I started by centering the servo electronically, and then hooking up the gyro. It seems like the gyro is doing what it's supposed to do as far as correcting the yaw of the heli, but...
...wht does the servo act all funny? Its like the servo's response to stick input is no longer linear, and the end-points are all screwy now. Also, the servo moves veeerrrryyy sllooowwwwllllyyy when I move the stick. How do I fix this, anyone?
_____________________________
#26 Club Saito
RIP, W.R.
       Post #: 1
RE: Blade 400 gyro setup??? - 7/3/2008 9:25:18 PM
evdreamer
Status: offline
Are you in rate or HH mode?
Nick
Since I started this hobby money seems to keep disappearing. :)
T-Rex 450SEV2, Gaui 200 SD
(in reply to flycfii)
       Post #: 2
RE: Blade 400 gyro setup??? - 7/3/2008 10:43:46 PM
flycfii
Status: offline
Well, let's make sure I understand the operation of the gyro correctly. 50 or less is rate mode, anything above 50 is considered HH, correct? But it acts the same at 50 or 60 or whatever.
#26 Club Saito
RIP, W.R.
(in reply to evdreamer)
       Post #: 3
RE: Blade 400 gyro setup??? - 7/4/2008 4:47:01 AM
evdreamer
Status: offline
I believe on the G110 that you are correct. The servo will always act a little different than you think it should in HH mode. Lower the gain below the 50 percent mark and it should act like there is no gyro and like you connected the tail servo right to the rudder channel. But it won't hold as good in rate mode. Rate mode is used to set up the tail servo. Then go to HH mode when flying.
Nick
       Post #: 4
RE: Blade 400 gyro setup??? - 7/4/2008 9:44:05 PM
flycfii
Status: offline
OK guys, I think I'm getting the hang of it. Did OK on my 3rd battery this afternoon, managed to at least pretend I could hover
I think its just going to take time and tweaking on my part to get this little heli dialed in properly. I get the gut feeling that the worst crashes happen only after you have the bird tuned to perfection!
#26 Club Saito
RIP, W.R.
(in reply to lzstar)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU1
