Chinese ARf alu servo mount
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> Chinese ARf alu servo mount
Page: [1]
Login
Chinese ARf alu servo mount - 7/4/2008 11:06:39 AM
Rider-60
Status: online
Hello,
I'm wondering if it is better to mount the servos with or without rubber grommets on "L" shapped servo mounts, looks like they mount it without but I can't find any good reason, any tips?
Florent
       Post #: 1
RE: Chinese ARf alu servo mount - 7/4/2008 11:43:36 AM
Jascat100
Status: offline
I never use the rubber grommets. I use screws, washers & nuts.
There is not the same level of vibration with jets compared with prop planes.
_____________________________
JET FLYING:- Resistance is futile. You will be assimilated.
(in reply to Rider-60)
       Post #: 2
RE: Chinese ARf alu servo mount - 7/4/2008 1:57:19 PM
jetnuno
Status: offline
Hi
The vibration level in turbines is almost zero. So, no need for rubber grommets. On the other hand, you get a more direct control and avoid flutter.
The downside is that you have to be carefull on taxing specially with elevators that do not have the shaft in their own CG. Avoid bumps
Nuno
       Post #: 3
RE: Chinese ARf alu servo mount - 7/4/2008 2:25:34 PM
Spartan Missile
Status: offline
Just watch out with some of these chinese bits of angle aluminium
Some of them can be as soft as cheese, threads easily stripped.
But you could always drill out a clearance hole and put a nyloc nut on the other side I suppose.
I prefer the black glass/carbon impregenated nylon brackets from BVM or TAMs
You can do the self tapping screws up like a gorilla and they don't strip.
< Message edited by Spartan Missile -- 7/4/2008 2:45:02 PM >
(in reply to jetnuno)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
