Which servo goes where...??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> RC Helicopter General Discussions >> Which servo goes where...??
Page: [1]
Login
Which servo goes where...?? - 7/4/2008 1:00:57 PM
legine
Status: offline
Hey guys i just got my Belt CP and im changing the stock Rx over to my JR Rx and use it with my JR Tx......I dont know which servos plug into which channel on the Rx.
Lets start at the ESC, im assuming it plugs into the throttle channel on the Rx.
Then the wire coming from the gyro goes into the rudder channel......this is as far as i got.
Lets call this servo, servo 1:
What chanel on the RX do i plug it in to, Aileron, elevator, Gear, Aux1 or Aux2???
Lets call this servo, servo 2:
And finally this will be servo 3:
Im sure this stuff would be in the manual but seeing as mine didnt have a manual in it for some reason I dont know.
I hope i have understood my problem clear enough, any help will be greatly appreciated, also if anyone sees a problem i might encounter by changing Rx and Tx please let me know........and yes i know that the rotor gear is stripped, does anyone know that part number???
Thanks a lot, Daniel
< Message edited by legine -- 7/4/2008 1:35:15 PM >
       Post #: 1
RE: Which servo goes where...?? - 7/4/2008 3:21:28 PM
Druss
Status: offline
The front servo (#1) is the elevator, the other two are ail and aux1 and it doesn't matter which you choose. If the response is reversed just change the sign on the value in the swash mix menu.
as for the main gear, i suggest you get the main gear from the blade 400 as it's tougher and fits perfect. get the one with the bearing preinstalled though as those are very hard to push out and put back in.
(in reply to legine)
       Post #: 2
RE: Which servo goes where...?? - 7/5/2008 5:37:31 AM
legine
Status: offline
thanks a lot for that!
The seller i got it from is sending me a new rotor gear, along with a manual and another set of main blades
Thanks, Daniel
(in reply to Druss)
       Post #: 3
RE: Which servo goes where...?? - 7/8/2008 1:07:02 AM
davideh2
Status: offline
Also looks like your swash setup is off a bit if those photos are showing servos and linkages at bottom stick on throttle and mid stick on ail/elev. in normal mode.
       Post #: 4
RE: Which servo goes where...?? - 7/8/2008 1:29:24 AM
legine
Status: offline
in that photo, nothing was connected at all....I connected it all up, centered everything and now im just waiting for my pitch gauge to get here.
Thanks, Daniel
(in reply to davideh2)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.313RCU1
