gas engine test stand
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> gas engine test stand
Page: [1]
Login
gas engine test stand - 7/4/2008 2:39:57 PM
xsnrg
Status: offline
Just wondering if anyone has built a test stand for a gas engine.I bought a 26cc CRRC engine and want to break it in on a test stand. I would like to see some examples of test stands....Thanks
       Post #: 1
RE: gas engine test stand - 7/4/2008 2:52:03 PM
soarrich
Status: online
Do a search of the forum, you'll get lots of pictures.
Gas engines shake more than the little nitro engine, for that reason it's not considered a good practice to run them on a test stand. You would be better off mounting it in your plane and running it, they are much cleaner running so you wont end up with a big mess. It's good practice to put the wings on for you engine runs they help dampen the vibrations.
_____________________________
Rich Border
(in reply to xsnrg)
       Post #: 2
RE: gas engine test stand - 7/4/2008 3:09:54 PM
RC Extreme power
Status: offline
Here is one that I build to test larger engine, but I only use it for testing, Not breaking in, I do that on the plane
Click to see fullsize image.
Click for fullsize
Importer of high performance RC gas engines
www.rcextremepower.com
(in reply to soarrich)
       Post #: 3
RE: gas engine test stand - 7/4/2008 3:44:22 PM
tomyrcmodels
Status: offline
universal test stand, but you need standoffs for your engine to fit it
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
tommyfly
(in reply to xsnrg)
       Post #: 4
RE: gas engine test stand - 7/4/2008 3:53:57 PM
pe reivers
Status: online
Nice engine Tommy. I like the large cooling fins.
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl
There is sanctuary in analisys.
(in reply to tomyrcmodels)
       Post #: 5
RE: gas engine test stand - 7/4/2008 4:36:23 PM
xsnrg
Status: offline
Hey Tomy....did you make that from scratch...if not where might a guy get one?
(in reply to pe reivers)
       Post #: 6
RE: gas engine test stand - 7/4/2008 4:48:28 PM
wjvail
Status: offline
http://www.****/forums/fg93/2510-gas-engine-test-stand.html
Some other ideas.
Bill
"Well, Nothing bad can happen now."
(in reply to xsnrg)
       Post #: 7
RE: gas engine test stand - 7/4/2008 5:04:32 PM
xsnrg
Status: offline
wjvail.....your link doesnt work.
(in reply to wjvail)
       Post #: 8
RE: gas engine test stand - 7/4/2008 5:48:24 PM
wjvail
Status: offline
Oooops. Sorry... I guess there is some censorship going on. Where the " **** " appears, insert GlyingFiants.com with the "F" and "G" transposed.
Bill
(in reply to xsnrg)
       Post #: 9
RE: gas engine test stand - 7/5/2008 6:19:53 AM
hellyeh
Status: offline
Try this guy out , he makes a very nice stand . I have bought several off him to supply to friends after they saw mine . His workmanship is outstanding and he's a nice guy to deal with too . clicky
       Post #: 10
RE: gas engine test stand - 7/23/2008 10:28:43 PM
nwcamp
Status: offline
I use a fuselage from a crash , seated in the flight box. It simulates a model, ie, it is not rigid, allowing model like movement while running engine. It allows reciever, servo and switch mounting, etc. Futaba says use an FM reciever for setup, not a PCM which will mask ignition caused glitches.
(in reply to hellyeh)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
