Thomas B
TX, USA Status: offline
quote:
ORIGINAL: NorfolkSouthern quote:
ORIGINAL: Thomas B A brilliant modeler in Germany has come up with a fantastic idea.....the perfect recycling of a Baby Bee .049.....into a brushless Cox .049 conversion.... He ditched the piston and rod and crank, made a new aluminum fake cylinder to save a bit of weight, and he hid a brushless outrunner inside the old tank, with the propshaft running through the old crankcase to the prop. I bet he polished up a dead glowplug to cap it off! No more devarnishing...no more tank leaks..no more o-ring problems...no more reed replacing...no more worn out needle valves....no more expensive glow plugs! If you simply must have the Cox noise, I am sure you could build a something for the prop to brush against.... I borrowed one picture to show the basic idea......the full info, more pictures and a video is over at: http://www.rcgroups.com/forums/showthread.php?t=888673#post10080796 I would never convert my Tee Dees...but I just might convert my lowly old Baby Bee, or even a well used Black Widow!... That's stupid, and the work involved to get the finished product was even dumber. A perfectly good engine was trashed, and made into an insulting piece of junk with a fake cylinder. NorfolkSouthern Not stupid at all....it is a fine piece of fun engineering. I have seen several rubber powered models with fake glow cylinders...and I have seen single cylinder motors with extra fake cylinders to simulate a multi cylinder motor. This is simply the logical progression of the fake powerplant and one of the most ingenious ones I have seen. I question your assumption that it was done to a perfectly good motor...how do you know it was not run out or flawed in some way? Let's face it...the single port Babe Bee .049 is one of the least desirable Cox motors around. Most people prefer a Black Widow or other hotter and longer running reedie for flying purposes. I have 2-3 of the lowly Babe Bees m in my motor box, worn out years back. Why waste precious Cox parts rebulding a Babe Bee when those same precious parts would be better used on the better reedies? Converting one to an electric outrunner |
