JetCat Smoke system
Tower Hobbies
Logged in as Guest
  Printable Version
AMT AT180 - RTF
Seller:  aparchment
Details:   $2,200.00   |  9/28/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> JetCat Turbine Direct Support >> JetCat Smoke system
Page: [1]
Login
JetCat Smoke system - 7/5/2008 12:15:38 AM
bcovish
Status: offline
I'm going to run the smoke pump (JetCat) off the ECU battery which is a Duralite 7.4 Li-Mn. Do I need to put a regulator between the battery and the smoke pump or will the pump handle the voltage which is about 8.3 coming off a fresh charge.
_____________________________
Bob-O Austin TX
Sticks and stones may break our bones, but words will break our hearts
       Post #: 1
RE: JetCat Smoke system - 7/5/2008 1:17:59 AM
quist
Status: offline
No need for a regulator.
btw, If you use the ECU to operate the smoke pump you can't vary the flow in the air.
(in reply to bcovish)
       Post #: 2
RE: JetCat Smoke system - 7/5/2008 1:30:24 AM
bcovish
Status: offline
I just have it "Y'd" off the ECU battery lead for power to the pump
I have it aux 4 (knob) to adjust the flow rate and turn it on and off with the mix switch (switch behind the Rudd D/R switch) that way I can adjust flow while in the air.
Is there a better way to do it? I'm open for suggestions.
< Message edited by bcovish -- 7/5/2008 1:40:36 AM >
Bob-O Austin TX
(in reply to quist)
       Post #: 3
RE: JetCat Smoke system - 7/5/2008 3:18:48 AM
quist
Status: offline
Sorry, I thought you were using the ECU to control the unit. You are doing it just as I did. It should work great.
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU1
