8ight axle build problem
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> 8ight axle build problem
Page: [1]
Login
8ight axle build problem - 7/5/2008 1:02:36 PM
jonrocat
Status: offline
Ive run into a problem with my build, im up to Im building the front spindle and CV assembly(step B-05). IT seems like the axle dosent stick out far enough from the spindle to allow the pin to slide through the wheel hex and axle, the hole dosent open up enough but with the wheel hex off there is just enough room to get the pin through and i mean JUST ENOUGH its very tight.
Now ive made sure both bearings are in the spindle as far as they can go, they are fluch with the outer edges. So it seems like ether the axle is to short or they have put the hole in the axle too close to the spindle to allow the pin to go through or im doing something wrong but i really cant see what it is!
BTW: its happening on both spindles, axles and pins.
With the wheel hex on its even worse and there's no way i can get the pin to go through, what am i doing wrong? Or has losi screwed up and punched the holes out of alignment?
< Message edited by jonrocat -- 7/5/2008 1:03:29 PM >
       Post #: 1
RE: 8ight axle build problem - 7/5/2008 2:12:08 PM
Dawman
Status: offline
I responded in your other thread about this . You need to make sure the bearings are seated correctly along with the cvd . After looking at mine , the inner bearing must be pushed in all the way , not flush . You will need to push really hard or tap it in with a piece of wood and a small hammer .
(in reply to jonrocat)
       Post #: 2
RE: 8ight axle build problem - 7/5/2008 2:54:17 PM
jonrocat
Status: offline
Yep thanks for the advice i did just that and it seated in another mil and now the pins and hex's are on. Thanks again.
(in reply to Dawman)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
