Bob Pastorello
Joined: 2/23/2002 From: El Reno, OK, USA Status: online
I will be posting this on my website also on my A123 info page. Email me, and I'll send you full size jpg's, if that will help. In the first diagram, the switch labeled "Receiver" connects to the Data Port (if using the JR 921 or AR9000 rx's). To CHECK the data, you must leave the OTHER switch ON after landing, leave the TX on, plug your data logger into the Receiver "Charge" receptacle, THEN *Turn OFF* the Receiver switch. The Data Logger can then be used as advertised. After checking, be sure to turn OFF the other switch, and the TX. To "BIND", leave the BIND switch OFF. Plug in your binding plug in it's "charging receptacle". Turn *ON* the "DATA" switch. You should observe the RX's in "fast blink". Depress the bind button on your TX while powering it up, and hold it depressed until all RX leds go solid. Release the TX bind button. Turn OFF the "DATA" switch. Unplug the binding plug. Check your system. I'm running two airplanes configured like this, and after using my trusty Dymo Labelmaker to help me keep everything straight, found out that these work just fine.
< Message edited by Bob Pastorello -- 7/15/2008 2:21:00 PM >
_____________________________
Bob Pastorello www.rcaerobats.net Learn from others...you can't live long enough to make all the mistakes yourself....
