pe reivers
Joined: 1/23/2002 From: Arcen, , NETHERLANDS Status: offline
18x6 seems the prop to go with good acceleration, and sufficient pull-out power. 18x8 pulls harder, but spools up slower. I do not know the putoline oil you mention. I did have intensive contacts with the Putoline tech rep, but this oil never came up. Do you have spec's ? Putoline oils I know of, and stock: MHX: top of the line SAE 50 grade all out racing oil, hot case engines like in watercooled, advised for the MVVS 1.60 RS 959: SAE 30 grade racing oil, for air cooled engines cart oil, castor based premix. Can be used in glow, and diesel engines. Putoline (now subdevision of Kroon oils) is made in Holland, and the TT sports oil is not known here?
_____________________________
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl There is sanctuary in analisys.
